Carl
CRTMPRP
2012 MAHINDRA MAX 28XL HST
I have a 28 xl and can not get power to the switch key when it does it will crank and run for a while and then go dead but it will crank and run a while. Now I can not get any power to switch at all I have checked all the fuses and they are good. the only fuse that does not have any power is the fifty amp next to the starter. I have power to the QGS controller and at the main fuse in the fuse box. Where do I need to look for the problem now
Trace the 50 amp fuse wire back to the battery. Wire is broken or loose @ battery.:thumbsup:
/ Carl
the 50 amp fuse close to the battery is good it is the other 50 amp fuse and the wires go thru the firewall
LandHonor LHR-UBF10 10in Utility Blower Fan (A60352)
LandHonor...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2023 New Holland C327 Two Speed Compact Track Loader Skid Steer (A61567)
2023 New Holland...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2014 Ram 1500 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 Crew...
