Carl
   / Carl #1
CRTMPRP
2012 MAHINDRA MAX 28XL HST
I have a 28 xl and can not get power to the switch key when it does it will crank and run for a while and then go dead but it will crank and run a while. Now I can not get any power to switch at all I have checked all the fuses and they are good. the only fuse that does not have any power is the fifty amp next to the starter. I have power to the QGS controller and at the main fuse in the fuse box. Where do I need to look for the problem now
   / Carl #2
Trace the 50 amp fuse wire back to the battery. Wire is broken or loose @ battery.:thumbsup:
   / Carl
the 50 amp fuse close to the battery is good it is the other 50 amp fuse and the wires go thru the firewall
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Bobcat 60" Skidloader Sweeper (A50774)
Bobcat 60"...
Utility Trailer (A50515)
Utility Trailer...
2012 Ford Explorer (A50120)
2012 Ford Explorer...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
