carbon in exh
/ carbon in exh #1
tmar04
YM 276
I seem to be getting a lot of carbon build up, and collecting, in my exh pipe. I have Yanmar YM2500, has on oil burning problem that I suspect is broken, or stuck oil rings. Just haven't had a chance to repair yet. wonder if my upcoming ring and bearing replacement will correct the exhaust carbon problem?? tractor starts and runs great. even on the coldest days. any thoughts?
/ carbon in exh #2
I would suspect that you have weak valve seals and possibly loose valve guides allowing oil to be sucked into the exhaust stream and partially burnt - leaving the residue.
Rings would make it hard to start from low compression, especially noticeable on cold days.
Do a wet and dry compression test by pulling a glow plug or injector. (varies by engine design) You will need a diesel tester that goes to 500 psi.
jb
/ carbon in exh #3
I agree with John Bud. With bad valve seals it'll smoke but still run good. With bad rings it'll run bad. I would pull the valve cover and take off the valve springs and put on valve seals. If it starts smoking again you'll have to pull the head and replace/insert/machine the valve guides and install new seals again.
2013 Komatsu PC210LC-10 Hydraulic Excavator (A60352)
2013 Komatsu...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Camper Trailer (A61569)
2014 Forest River...
Land Honor HPF-11-3000G Heavy Duty Hydraulic Forks and Frame Skid Steer Attachment (A60352)
Land Honor...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
