Carb removal on small Briggs & Stratton 5hp engine on Ariens RT5...20 tiller
   / Carb removal on small Briggs & Stratton 5hp engine on Ariens RT5...20 tiller #1
jpilk99
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
I've done this before (removing carb) but it's been a while and I'm baffled as to how to get this carb off; (see pics). It's mounted atop the small gas tank and getting access to everything is a challenge. I've gotten all the bolts/screws off but now cant remove the governor/throttle linkage (I believe) from where it snaps into the carb linkage - and with that long tube extending down into gas tank from carb, and can't just rotate the carb to disengage linkage.
   / Carb removal on small Briggs & Stratton 5hp engine on Ariens RT5...20 tiller #2
If my memory is correct you have to remove the gas tank and carb as an assembly to allow rotation to remove that linkage? I wouldn’t bet the farm on my memory being correct though….
   / Carb removal on small Briggs & Stratton 5hp engine on Ariens RT5...20 tiller #3
Ack, I’m having a recurring nightmare after reading this. I just got through messing with a friends tiller with a similar setup. Oldnslo is correct, on his I’d have to take the tank off and tilt it and the carb just right to get the linkage disconnected.
   / Carb removal on small Briggs & Stratton 5hp engine on Ariens RT5...20 tiller #4
Not a post about how to pull carb but I faced same problem of replacing carb. Ordered new carb last year with intention of replacing on my tiller. Had not been run in years, so I thought I would try to get it going. First I poured seafoam down air intake until it stalled, would run if you poured gas down carb but stop when it used that up. Let set for 2 days, replaced rubber diaphragm, then I emptied all the old gas out of tank and mixed 1 qt. of gas and 1 ounce of seafoam. Poured some of the mix down carb and started pulling rope. Started after about 10-12 pulls, running rough at first but leveled out. Now starts with 2-3 pulls and runs like it used too years ago.
Thanks all!!!! Tank removal it is!!!
   / Carb removal on small Briggs & Stratton 5hp engine on Ariens RT5...20 tiller #6
I start by removing the 2 screws that secure the control panel to the carb and tank. With that out of the way. I remove the bolt that holds the L bracket with the throttle linkage. You can twist the L bracket to get the linkage out of the bracket.. And then pop the other control out of the holder to the left of the L bracket that had the shoulder bolt. And then remove the remaining 3 screws that secure the carb to the tank. Remove the 2 bolts that connect the carb to the engine block. and you should be able to remove the carb without removing the tank.
I do it that way to avoid having to deal with disconnecting and reconnecting the governor spring. Which can be a challenge within itself sometimes.
Thanks Randy. I think I did some variation of this the first time as I didn't remove the tank. But removed tank today and kinda glad I did - the governor arm and that geared/slide down at the bottome of the bracket as an oily gunky mess!!!
But now my issue is that I am not sure that I got all the linkages back, not so much in the right place, but in the right order. The throttle & governor linkages seem to be running into the choke linkages. Anyone ever seen a video removing/reinstalling one of these? And what kind of carb is this? I cant find a parts diagram for the "Briggs 5 HP" engine on the tiller. Briggs usually has Model & Type numbers stamped on OHV covers, but this machine obviously doesn't have those.
Thanks again!!!
Oooo: Look what I found:
Ooo again. A great "Taryl fixes all" video:
Thanks again!!!
And of course I found the info stamped on the engine housing!
Kubota B2301 (A53317)
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
2011 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A55314)
2011 MACK Tender...
Volvo A40D Off Road Dump Truck (A55314)
Volvo A40D Off...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55853)
2023 Fat Truck...
