Carb problem
/ Carb problem #1
The Cub
Cub cadet 1250
Hi guys , I had the carb off my tractor and now that I've reinstalled it the tractor runs fine until I put the air filter on and then it starts to run like crap and black smoke comes out the exhaust what could be going on ? I was thinking maybe I'm sucking air in through a gas line .
/ Carb problem #2
black smoke indicates a rich fuel mixture. Re-check your carb air cleaner filter cartridge(s) to be be clean and properly installed. Also make sure carb choke mechanism is not being partially closed by installed air filter.
/ Carb problem
Thx I'll check it out tonight . Could it be sucking air were the carb mounts to the motor and cause it to run like crap?
/ Carb problem #4
If sucking air between carb and motor it would be running lean. Black smoke, as rcbe stated, indicates a rich mixture (too much fuel / not enough air). Check your air cleaner, also verify nothing is pushing the choke closed. Something is restricting air flow.
/ Carb problem
Thx for all the tip guys , I'll try and fix this tonight so I can cut the grass over the weekend . Its getting long
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
AGT Mini Excavator Attachment Set (A64127)
AGT Mini Excavator...
Genie GTH-844 (A64126)
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
