Carb problem
   / Carb problem #1
The Cub
Cub cadet 1250
Hi guys , I had the carb off my tractor and now that I've reinstalled it the tractor runs fine until I put the air filter on and then it starts to run like crap and black smoke comes out the exhaust what could be going on ? I was thinking maybe I'm sucking air in through a gas line .
   / Carb problem #2
black smoke indicates a rich fuel mixture. Re-check your carb air cleaner filter cartridge(s) to be be clean and properly installed. Also make sure carb choke mechanism is not being partially closed by installed air filter.
   / Carb problem
Thx I'll check it out tonight . Could it be sucking air were the carb mounts to the motor and cause it to run like crap?
   / Carb problem #4
If sucking air between carb and motor it would be running lean. Black smoke, as rcbe stated, indicates a rich mixture (too much fuel / not enough air). Check your air cleaner, also verify nothing is pushing the choke closed. Something is restricting air flow.
   / Carb problem
Thx for all the tip guys , I'll try and fix this tonight so I can cut the grass over the weekend . Its getting long
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52128)
2018 Rock Solid...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A51222)
2019 FREIGHTLINER...
434669 (A48836)
434669 (A48836)
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
