Carb Issues
/ Carb Issues
I changed out the plugs and wires and adjusted the points. I then started adjusting the carb and I got it running darn near perfect. I took it out for a spin, the first time since changing the clutch out, I went around for a while and then all of a sudden, it wouldn't move anymore. No grinding, no noise, no nothing. Just wouldn't move. I tried adjustment the clutch pedal but unless I took the pedal all the way loose it wouldn't ever go into gear. If it was completely loose then it would grind if I tried to put it into gear.
At this point I am done. It is heading to the shop.
Thanks,
Stuart
/ Carb Issues #12
Sorry it turned out this way, **** old tractors anyway, It was made about the same time as Packard Bell, AOL and windows 3.1 ,
/ Carb Issues #14
I've encountered the problem of an engine that idles ok, but pops and backfires when you try to rev it . Once, the problem turned out to be a bad condenser in the distributor. Condensers can go bad at any time, even if they're new. In another case, the carburetor was too lean to run well off idle . Fine white deposits in the fuel were going right through the fuel filter, and accumulating in the carburetor . I installed a spin-on 10 micron fuel filter, and the engine problem never appeared again .
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2020 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A59230)
2020 GMC Sierra...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
