Car lift problem
/ Car lift problem
Yep. Had mine apart a few years ago.
Yes i am working alone too... I used a strap to hold it together, then I unbolted it and then pulled it down while removing the strap.
/ Car lift problem
I took his posts to refer that the lift works fine if he starts it with it completely down or if he pushes the down lever as he starts it???
Both ways work. sorry for the confusion.
/ Car lift problem #23
So we would be correct to assume the pump isn't locked up?
It's more likely that the motor won't start the pump if there's any kind of load on it?
/ Car lift problem
The motor seems OK. Do not try to run the motor for more then 2 seconds if it will not start. There is no thermal shut off.
60Amps by 230Volts generates more than 10.000 Watts in heat in a blocked motor! ( 30.000 BTU per hr.)
If the motor runs OK when you hold the hydraulic lever in the "lower" position, than the pump should be OK. Check the hose to the cylinder for pinched or kinks, check steel cables, sheaves, and other mechanical. It looks to me that something is preventing the oil to flow to the cylinder or something prevents the cylinder from extending.
My mechanic thought the hose could be bad too. How would I test that? Thanks for the help everyone.
/ Car lift problem #25
Hmmmm.... I'll have to think about that a bit.
/ Car lift problem #26
Loosen the connection (do not take it apart) on the pump end of the hose en see if oil is pushed out when running the motor/pump. Then do the same at the cylinder end of the hose.
Be careful for the pressurized oil, you could wrap a transparent plastic bag around the coupling to prevent oil spraying on you.
/ Car lift problem #27
Just throwing something out here. Is there a weight limit switch in the system?
/ Car lift problem #28
No safety switch because it is a 4 post lift. In the magnet switch it is bypassed. The cables just max out.
Is there a mechanical lock to hold it up if something fails with the cables and or the hydraulics?
If so, can you lower the car to be held by the mechanical lock before starting the motor to raise it higher (as a workaround)?
Aaron Z
/ Car lift problem #29
Another thought; there must be a "one way valve" close to the lever, I think, to prevent the platforms from lowering once you stop the motor/pump. If this valve is stuck in the closed position, than the oil can't leave the pump.
I would be behind one of the caps.
/ Car lift problem #30
This seems to make sense, there should be a check valve.
/ Car lift problem #33
Aaron Z
Yes. They vary depending on brand. I always lower the load until the mechanical lock relieves pressure from the system before going under a vehicle. Then I am required to lift the vehicle slightly to release the mechanical lock before lowering to the ground. So, in that situation, my pump is always starting with no load.
I've never tried leaving the load on the hydraulic system to see if it drifts downward. My Jeep is parked on it now. I'll lift it without engaging the lock and let it sit there for awhile to see if it drifts downward.
/ Car lift problem
Maybe attached diagram will help you out. View attachment 642769
Thank you, I will try to check the check valve today. Thanks everyone for all the help. I wish the manufacture would call back, they said 24 to 48 hrs. Its about 48 hrs now.
/ Car lift problem #35
Held my Jeep for an hour without being locked, no drift.
/ Car lift problem
Can you put the 9540 on your lift? I am kinda jealous of your tractor, that size is what I would like to trade my MX5100 for. :thumbsup:
/ Car lift problem #37
It would fit. I've never done so. It's easy to get under on a creeper.
I've had my Ford on it with no problems.
I think my Diesel SD weighs right around 7K. Handles it with no problems. My lift is "Forward" brand. It's an old lift that uses horizontal cylinder and chains.
/ Car lift problem
I took out the check valve and the release valve, and they both appear to look and function correctly. I still have not heard back from the manufacture. They are suppose to call me by the end of today.
/ Car lift problem #39
Have you had any hoses off for any reason and a few days later put them back on? I had a situation where a wasp plugged up a hose far enough in that I didn't see it. The system did not work. Took awhile to find it.
/ Car lift problem
No, I have not. But the way the hose was originally ran, I question if it may have kinked up or internally collapsed. Here is a video since the manufacture wanted a video. I posted it up on YouTube. I am a star now.... first video ever. :thumbsup:
Kubota M125X (A60462)
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
John Deere 772CH (A64126)
John Deere 772CH...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
