Car lift in garage
   / Car lift in garage #14
My son just put this in his shop. He knows his stuff and did a lot of research. Mostly for working on his old Bronco and GTO.
I have a fairly low (10FT) ceiling and have the exact same lift! Excellent! It does say in the manual you need a minimum of 4" of concrete.. Easy to install and I used it on a crew cab F150 (biggest thing I used it on) and worked great. I mainly bought ti for working on side by sides but use it a LOT on my Jeep and wife's RAV4.
Once you get a lift you will wonder how you lived without out it.
   / Car lift in garage #15
I have a fairly low (10FT) ceiling and have the exact same lift! Excellent! It does say in the manual you need a minimum of 4" of concrete.. Easy to install and I used it on a crew cab F150 (biggest thing I used it on) and worked great. I mainly bought it for working on side by sides but use it a LOT on my Jeep and wife's RAV4.
   / Car lift in garage #16
MOBILEMAN 6, lbs. Single-Post Lift
This is not the brand or as heavy duty as a friend put in his shop but I liked the portability of the concept. I think the price was $4K+ but is good for a diesel dually PU.
   / Car lift in garage #18
I think if you are looking into a post lift you should go to several manufacturers sites and see what they recommend. I know Mohawk gives detailed instruction on the installation of there lifts. They have very nice lifts. Bob
   / Car lift in garage #19
What are the best type of car lifts for a garage? A 2 post or 4 post?
With a 12-14 foot ceiling height and a 4 inch slab at 3,500 psi. Is that adequate for a lift?
First, As posted that will not be thick enough concrete and also it needs to have rebar if going with a 2 post.
Have a neighbor that bought a used 4 post and didn't even mount it down at first. Worked fine -Not sure of the model, but it came out of a Les Schwab Tire center.
2 or 4 post debate still on going. :D
My son and I work on a lot of cars and trucks and went with a 2 post asymmetrical 10k lift.
If you anticipate the need to
remove a body from a frame-2 post
change a lot of tires and wheels-2 post.
front subframe removal -2 post
front or rear axle removal -2 post
There are attachments to get some of these jobs done with 4 posts.
If you can't change the concrete, A 4 post seems to make more sense.
For changing oil/filters or exhaust work in high production shop -4 post all day, no need to get on the ground and set lift points just drive on.
Very happy with my 2 post lift It gets used far more than I ever thought it would.
   / Car lift in garage #20
It would be fairly easy to cut ou and replace a chunk of concrete where the lift would anchor down.
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
JOHN DEERE 7210R LOT NUMBER 269 (A53084)
JOHN DEERE 7210R...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
