Car lift in garage
   / Car lift in garage #14
My son just put this in his shop. He knows his stuff and did a lot of research. Mostly for working on his old Bronco and GTO.
I have a fairly low (10FT) ceiling and have the exact same lift! Excellent! It does say in the manual you need a minimum of 4" of concrete.. Easy to install and I used it on a crew cab F150 (biggest thing I used it on) and worked great. I mainly bought ti for working on side by sides but use it a LOT on my Jeep and wife's RAV4.
Once you get a lift you will wonder how you lived without out it.
   / Car lift in garage #15
I have a fairly low (10FT) ceiling and have the exact same lift! Excellent! It does say in the manual you need a minimum of 4" of concrete.. Easy to install and I used it on a crew cab F150 (biggest thing I used it on) and worked great. I mainly bought it for working on side by sides but use it a LOT on my Jeep and wife's RAV4.
   / Car lift in garage #16
MOBILEMAN 6, lbs. Single-Post Lift
This is not the brand or as heavy duty as a friend put in his shop but I liked the portability of the concept. I think the price was $4K+ but is good for a diesel dually PU.
   / Car lift in garage #18
I think if you are looking into a post lift you should go to several manufacturers sites and see what they recommend. I know Mohawk gives detailed instruction on the installation of there lifts. They have very nice lifts. Bob
   / Car lift in garage #19
What are the best type of car lifts for a garage? A 2 post or 4 post?
With a 12-14 foot ceiling height and a 4 inch slab at 3,500 psi. Is that adequate for a lift?
First, As posted that will not be thick enough concrete and also it needs to have rebar if going with a 2 post.
Have a neighbor that bought a used 4 post and didn't even mount it down at first. Worked fine -Not sure of the model, but it came out of a Les Schwab Tire center.
2 or 4 post debate still on going. :D
My son and I work on a lot of cars and trucks and went with a 2 post asymmetrical 10k lift.
If you anticipate the need to
remove a body from a frame-2 post
change a lot of tires and wheels-2 post.
front subframe removal -2 post
front or rear axle removal -2 post
There are attachments to get some of these jobs done with 4 posts.
If you can't change the concrete, A 4 post seems to make more sense.
For changing oil/filters or exhaust work in high production shop -4 post all day, no need to get on the ground and set lift points just drive on.
Very happy with my 2 post lift It gets used far more than I ever thought it would.
   / Car lift in garage #20
It would be fairly easy to cut ou and replace a chunk of concrete where the lift would anchor down.
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
