Cant shift into low range
/ Cant shift into low range #1
winniedog
L3010 HST I have no trouble shifting from mid range to hight range and back but can't get into low. It feels like the linkage may be jammed.
Anyone been through this?
Thanks for any help you can give me.
/ Cant shift into low range #2
Is your tractor in 4WD. If so put it in 2WD then try low range. Some tractors may cause binding or hard to get in low range when in 4WD. Not sure if this is your problem but worth a shot.
Yes it is in 4wd.
I'll give that a try. I'm a newbie to tractors. I leave it in 4wd all the time.
Is that ok? Thanks for your help.
/ Cant shift into low range #4
With just a little pressure on the shifter into low range, very lightly tap on the FWD/REV pedal. It might help the gears sync.
/ Cant shift into low range #5
Leaving in 4WD all the time is fine on soft ground (dirt, stone, gravel, grass, mud, etc) but not too good on hard surface like blacktop or concrete. Front and rear gear ratios are not exact and can cause binding. I believe the F to R gear ratio tolerance can be up to 5% different.
/ Cant shift into low range #6
It says HST. Thats for Hydrostatic drive. Not the same as gear binding with a Gear drive transmission. With Kubota, at least mine, you have to pump the brake pedal and clutch pedal alternately at times to get it to shift. Do not force it.
/ Cant shift into low range #7
Like the others have said, do not drive in 4x4 if you have a concrete or paved driveway. Otherwise I never take my Kubotas out of 4x4 unless I am on the road in top gear.
/ Cant shift into low range #8
I had the same problem on my Mahindra 2615HST. There were times when in 4WD low range that I couldn't shift out of low range. Had to take it out of 4wd then rock it forward and back with the HST pedal while applying pressure on the range selector to get it out. The tractor was on a gravel driveway but it was hard packed crusher run just like concrete. Also had to make sure the front wheels were straight.
/ Cant shift into low range #9
I have read on here that many Kubota HSTs are difficult to change ranges on; mine has been since new, now with about 400hrs. My technique is to shift (when possible) when the tractor is moving slightly. Else, like others have said, rock the HST pedal slightly or clutch/unclutch a few times. I think that the basic problem is that the range gears are straight cut and have no synchronizer rings, so range shifting will always be a little touchy.
- Jay
/ Cant shift into low range #10
Also, look underneath the floor board to make sure your linkage isn't bent. Mine buckled at some point and it was extremely difficult to shift. Straightened the linkage out and it greatly helped things out. Like others said, bump the FWD/REV peddle a little bit.
Thanks for all the great advise everyone. I'll try it out tomorow.
/ Cant shift into low range #12
I think when the tractor is new, things are a little stiff. On my B3030, I found easier to switch ranges after hitting neutral first.
Well I put it in 2wd and still no luck.
I'll look at linkage next.
/ Cant shift into low range #14
When I got my new Mahindra a few months ago I had the same problem. I found that if I pressed the fwd then the rev pedal while on a flat surface, clutch it a couple of times, it would eventually go into gear. As the hours added up, the problem lessened and now is nearly gone. It seemed to be just tight tolerances in mine, maybe yours as well.
good luck
/ Cant shift into low range #15
When my tractor was new - the range shift was stiff. Now I have a few hours on it the shift is a lot smoother.
/ Cant shift into low range #16
I agree on not running 4wd on hard surface but if I am mowing pasture where extra traction is not needed I don't use 4wd to me its less wear and better fuel mileage.
/ Cant shift into low range #17
I agree with Rocky - when not needed, I take it out of 4x4.
HP
/ Cant shift into low range #18
something is not right. On my bx, it might have trouble shifting h to l when I first had it , thats because I didnt know any better with HST. I was thinking like a car stick shift, clutch, then shift. or automatic -- stop completely and shift . With HST gearing, I learned its more of shifting the right moment without the clutch. I have gotten to the point where I dont think about it anymore.
Best advice I can give you is, be out of 4wd on grass. front wheels straight. hand on the h/l shift and hold it slightly in direction you want to shift and move tractor forward slowly and wait till it moves. DONT FORCE it!. all it takes is a slight pressure on handle, but before the binding feel. if this doesnt work -- take a look at this thread:
http://www.tractorbynet.com/forums/kubota-owning-operating/38039-cannot-shift-l3010-hst-into.html
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
