Can't remember if I added Stabil to these cans of gasoline...
   / Can't remember if I added Stabil to these cans of gasoline... #1
SmallChange
Platinum Member
New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
...so, is it a bigger problem if they get dosed twice? or if they don't get dosed at all?
If it helps, I think it's more likely that I did not add the Stabil.
   / Can't remember if I added Stabil to these cans of gasoline... #2
Double dose is no big deal. If the gas is older than 30 days I'd use it up in the car and replace with fresh, unless it's ethanol free.
   / Can't remember if I added Stabil to these cans of gasoline... #3
I’d go ahead and dose it. You could do a slightly lower dose if your worried about it.
   / Can't remember if I added Stabil to these cans of gasoline... #4
While youre dosing, change to Ethanol Shield. Better than StaBil
   / Can't remember if I added Stabil to these cans of gasoline... #5
Double dose used to be written on the bottle for longer storage periods so it won't hurt anything.
Edit: Website states it as well,
Dosage recommendations​
For seasonal storage, or when the fuel is likely to sit idle for more than 1-2 months but less than 12 months:
  • 30ml for every 9.5 litres of fresh fuel
For longer storage periods e.g. 12 - 24 months:
  • 60ml for every 9.5 litres of fresh fuel
For best results always store vehicles and equipment with a full tank of fuel rather than a near empty tank. Always run the engine for up to 5 minutes after adding STA-BIL® to ensure the entire fuel system is treated and not just the fuel stored in the fuel tank.
   / Can't remember if I added Stabil to these cans of gasoline... #6
Well that was a foreign version I just noticed, the US version doesn't state it the same way but does have this,
Will over-dosage cause any harm?​
No, over-dosage is perfectly OK. However, we do not recommend adding more than 4 times the recommended amount. If more than 4 times has been added we recommend diluting the fuel.
   / Can't remember if I added Stabil to these cans of gasoline... #7
Do you folks not have the option of ethanol free? Here (montana) usually the premium grade is without ethanol.
   / Can't remember if I added Stabil to these cans of gasoline... #8
Here in Nova Scotia we don't. Used to up until 1-1/2 2 years ago then poof, gone. I even tried the local yacht club figuring if anywhere had it they would, nope.
   / Can't remember if I added Stabil to these cans of gasoline... #10
Even if the fuel is ethanol free fuel stabilizer should still be used if stored for a month or more.
Cheap insurance. I’m using fuel additives everywhere. I only replaced one set of injectors @ $1,500 a piece.
We won’t be doing that again.
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
