Can't remember if I added Stabil to these cans of gasoline...
   / Can't remember if I added Stabil to these cans of gasoline... #1
SmallChange
New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
...so, is it a bigger problem if they get dosed twice? or if they don't get dosed at all?
If it helps, I think it's more likely that I did not add the Stabil.
   / Can't remember if I added Stabil to these cans of gasoline... #2
Double dose is no big deal. If the gas is older than 30 days I'd use it up in the car and replace with fresh, unless it's ethanol free.
   / Can't remember if I added Stabil to these cans of gasoline... #3
I’d go ahead and dose it. You could do a slightly lower dose if your worried about it.
   / Can't remember if I added Stabil to these cans of gasoline... #4
While youre dosing, change to Ethanol Shield. Better than StaBil
   / Can't remember if I added Stabil to these cans of gasoline... #5
Double dose used to be written on the bottle for longer storage periods so it won't hurt anything.
Edit: Website states it as well,
Dosage recommendations​
For seasonal storage, or when the fuel is likely to sit idle for more than 1-2 months but less than 12 months:
  • 30ml for every 9.5 litres of fresh fuel
For longer storage periods e.g. 12 - 24 months:
  • 60ml for every 9.5 litres of fresh fuel
For best results always store vehicles and equipment with a full tank of fuel rather than a near empty tank. Always run the engine for up to 5 minutes after adding STA-BIL® to ensure the entire fuel system is treated and not just the fuel stored in the fuel tank.
   / Can't remember if I added Stabil to these cans of gasoline... #6
Well that was a foreign version I just noticed, the US version doesn't state it the same way but does have this,
Will over-dosage cause any harm?​
No, over-dosage is perfectly OK. However, we do not recommend adding more than 4 times the recommended amount. If more than 4 times has been added we recommend diluting the fuel.
   / Can't remember if I added Stabil to these cans of gasoline... #7
Do you folks not have the option of ethanol free? Here (montana) usually the premium grade is without ethanol.
   / Can't remember if I added Stabil to these cans of gasoline... #8
Here in Nova Scotia we don't. Used to up until 1-1/2 2 years ago then poof, gone. I even tried the local yacht club figuring if anywhere had it they would, nope.
   / Can't remember if I added Stabil to these cans of gasoline... #10
Even if the fuel is ethanol free fuel stabilizer should still be used if stored for a month or more.
Cheap insurance. I’m using fuel additives everywhere. I only replaced one set of injectors @ $1,500 a piece.
We won’t be doing that again.
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2015 Freightliner Cascadia 125 Day Cab Truck, VIN # 3AKJGEBG5FSGD4138 (A54865)
2015 Freightliner...
Carnival Ticket Booth (A51691)
Carnival Ticket...
2007 Toyota Tundra Pickup Truck, VIN # 5TFBV54137X003941 (A54865)
2007 Toyota Tundra...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
