Mowing Can't lock mmm to top position on bx2360
   / Can't lock mmm to top position on bx2360
I think that's a big benefit of TBN - all of the veterans are patient with us newbies.
   / Can't lock mmm to top position on bx2360 #13
Have a new BX2360 with MMM, FEL and rototiller. I have 6 acres, mostly grass and intend to have a 1/4-1/2 acre garden. I'll also be doing lots of landscaping and building a garage. My problem is that I can't get the dial on the MMM to turn all the way to the "TOP" indicator. I see this as important for next spring hen I'll be tilling up the garden. Is there some trick not well documented in the manual, or should I address the problem with my dealer. I really don't want to detach the mower if I don't have to.
Tim,
I know taking that deck off/on isn't the most pleasant chores in the world, but I sure don't care to run the tiller etc. with that joker hanging under the tractor. Wear and tear not to mention the extra weight can be a hassle.
Believe it or not, it gets easier the more you do it. On the positive side, it's a good way to get a good thourough inspection of the deck, blades, pullies and bearings.
Big dad,
I don't have a flat surface (yet - have to build a garage!) but when I do I plan on it. Hopefully i get it done before spring and gardening season. If not, maybe a couple of sheets of plywood will suffice in the mean time. I really have to get the garage done, don't like keeping the BX2360 under a tarp.
   / Can't lock mmm to top position on bx2360 #15
Tim,
Oooooohhhhkay...... I can see why. It sure is much easier and safer on a nice flat spot.
Good luck!
Oh, and did I mention the wife also wants the cars under shelter? Another reason for building the garage.
   / Can't lock mmm to top position on bx2360 #17
We have a concrete drive we use to remove the deck on our BX, but not JD2305 and a piece of plywood, particle board or just a couple of wide boards work pretty well also. My sons have pulled them both off in grass and rock, but they are pretty strong. It can be done, but I don't recommend it.
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
ALLISON TRANSMISSION (A55745)
ALLISON...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
Informational Lot - Shipping (A56435)
Informational Lot...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2017 John Deere 5090GN (A53317)
2017 John Deere...
