Mowing Can't lock mmm to top position on bx2360
   / Can't lock mmm to top position on bx2360
I think that's a big benefit of TBN - all of the veterans are patient with us newbies.
   / Can't lock mmm to top position on bx2360 #13
Have a new BX2360 with MMM, FEL and rototiller. I have 6 acres, mostly grass and intend to have a 1/4-1/2 acre garden. I'll also be doing lots of landscaping and building a garage. My problem is that I can't get the dial on the MMM to turn all the way to the "TOP" indicator. I see this as important for next spring hen I'll be tilling up the garden. Is there some trick not well documented in the manual, or should I address the problem with my dealer. I really don't want to detach the mower if I don't have to.
Tim,
I know taking that deck off/on isn't the most pleasant chores in the world, but I sure don't care to run the tiller etc. with that joker hanging under the tractor. Wear and tear not to mention the extra weight can be a hassle.
Believe it or not, it gets easier the more you do it. On the positive side, it's a good way to get a good thourough inspection of the deck, blades, pullies and bearings.
Big dad,
I don't have a flat surface (yet - have to build a garage!) but when I do I plan on it. Hopefully i get it done before spring and gardening season. If not, maybe a couple of sheets of plywood will suffice in the mean time. I really have to get the garage done, don't like keeping the BX2360 under a tarp.
   / Can't lock mmm to top position on bx2360 #15
Tim,
Oooooohhhhkay...... I can see why. It sure is much easier and safer on a nice flat spot.
Good luck!
Oh, and did I mention the wife also wants the cars under shelter? Another reason for building the garage.
   / Can't lock mmm to top position on bx2360 #17
We have a concrete drive we use to remove the deck on our BX, but not JD2305 and a piece of plywood, particle board or just a couple of wide boards work pretty well also. My sons have pulled them both off in grass and rock, but they are pretty strong. It can be done, but I don't recommend it.
2018 Honda Odyssey Van (A56859)
2018 Honda Odyssey...
2016 Freightliner M2 106 4x4 Altec Bucket Truck (A55852)
2016 Freightliner...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
1991 John Deere 2355 (A53317)
1991 John Deere...
2015 Kia Sportage SUV (A55853)
2015 Kia Sportage...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
