Cant hook up bushhog..
   / Cant hook up bushhog.. #41
When I bought my last compact tractor I made sure that I had top and tilt,telescopic links and the IMatch setup. I retired the pinch bar and heavy hammers, don't need to worry about blocks or perfect landing pads for the implements anymore. Rarely does it take more than a minute or two to change between implements.
   / Cant hook up bushhog.. #42
Mine is 11-1200 pounds with the safety chains and on un-even gravel in the barn -- pretty sure that wouldn't work out. But I bet for lighter implements on smooth cement, it works slick. But a slightly more expensive iron pipe would probably be more prudent. PVC shatters at the worst times.
I had to build a low wooden platform. I use 1 inch pvc with my heavy duty 5 foot bush hog.
   / Cant hook up bushhog.. #43
After 20 years of using a tractor and I change a lot of implements daily, my best advise is to is to spend the money(less than $200.00) and buy a set of Pat's Quick Hitch. You will save banging your fingers and aggravation involved in equipment changes.
   / Cant hook up bushhog.. #44
I set the front of the hog on some 2x6 blocks, usually three under each side. If you can get one pin in, you've got it beat. There's usually a piece of 2x4 around for a lever, and grabbing the tailwheel to swing the front a little bit works too. Brute strength and ignorance seems to be the order of the day..
Sean
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
New/Unused Electric Golf Cart (A57453)
New/Unused...
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
JCB 2145 (A47477)
JCB 2145 (A47477)
