Can't get grapple line connected to 3rd function
/ Can't get grapple line connected to 3rd function #1
blb078
Wentzville, MO
LS 4150HC
I have a wrlong 3rd function kit on my LS tractor. The kit was put on by the dealer and it had some ag couplers. I took those off and put on 1/2" flat face skid steer quick connect style. I also put them on the grapple lines for the grapple I had. I can't get one of the lines to connect into the coupler. It use to work ok but required some force but now it will not connect at all. It pretty much goes all the way end except maybe the last 1/8" where it clicks. Any idea what is causing this and how to fix it? Only one of the two lines has this issue. The other line connects just fine.
/ Can't get grapple line connected to 3rd function #2
This should help you out.
Travis
/ Can't get grapple line connected to 3rd function #3
The ag style couplers are much easier to use and release pressure, just push the ball against some metal surface until it quits bleeding. All of my front mount attachments (at least 6) are the FFC because I have a skid steer and the tractor has them as well. The only advantage that I see with the FFC is that the dust is kept out without the funky rubber caps, and they are easy to wipe 100% clean. They are way more expensive and releasing pressure on the implement side usually means "cracking" or loosening the fitting, btw this and a few other reason have made me a big fan of JIC style fittings. Easy to loosen to "bleed" pressure off.
/ Can't get grapple line connected to 3rd function #4
First I move my FEL lever to release any built up pressure in the lines, and if there is a build-up remaining or at the actual implement instead of the tractor's lines, I carry a hammer in my on-tractor toolbox. I take it out and smack the side of the hammer head to the ball of the male JIC, while looking away, or wrapping the ball end with a rag to keep hydraulic fluid from spraying in my eyes, etc.
Ok, so basically I need to release the pressure on the grapple fitting then? Any easy way of doing this with the flat face skid steer fittings since it's all flat?
/ Can't get grapple line connected to 3rd function #6
Did you watch the video?
Turn the tractor off, then turn the key so accessory power is on to actuate the 3rd function switch. Press the buttons/rock the switch to relieve pressure.
That's it in a nutshell.
Travis
Travis
I've already done that. Probably should have mentioned that in my first post. Even after doing that I can get the coupler just to where its about to click but to much pressue.
/ Can't get grapple line connected to 3rd function #8
Mine is the same way. I end up having to loosen a fitting to relieve the pressure.
/ Can't get grapple line connected to 3rd function #9
Also make sure the FEL and any implement on the back are on the ground.Move your joy stick in all directions to relieve pressure on tractor.The heat of the sun will build pressure in your hoses on front implement also.
When you do that, do you losen the fitting, connect the coupler, then tighten the fitting back up? Or do you just losen the fitting for a sec, then tighten it back up, then connect the coupler?
/ Can't get grapple line connected to 3rd function #11
I just loosen the fitting to relieve the pressure, a small amount of hydraulic fluid will come out and then I tighten it back up and connect the coupler, about a second or so . . .
/ Can't get grapple line connected to 3rd function #12
Here are a couple ideas from my projects file and this old thread: http://www.tractorbynet.com/forums/hydraulics/131755-help-my-stucchi-disconnect.html
/ Can't get grapple line connected to 3rd function #13
Nice ideas Dennis!!!! Thanks for posting them!!!! :)
/ Can't get grapple line connected to 3rd function #14
You are welcome, Richard. :)
I have learned a lot on TBN, just trying to pass it on.
/ Can't get grapple line connected to 3rd function #15
Travis
That's why I like Ag connectors as you can whack them on anything to bleed off pressure.
I have such big swings in ambient temperature that I can have vacuum or pressure built up in an attachment depending on what the temp was when I disconnected, and what temperature it is when I reattach it.
Thanks, got it working had to loosen a fitting like txdon recommend and it connected right up.
/ Can't get grapple line connected to 3rd function #19
save your self some headaches and put ag couplers back on. the clamps xfaxman made will work but you can damage a fitting if you put to much force on them.
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
