cant fix the leak when its raining!
/ cant fix the leak when its raining! #1
schmism
Super Member
Peoria IL
New holland TC(33)
so This is the first spring ive had my property. We purchesed last aug.
So now we are finding all the low spots that hold water. And i have a tractor with various impliments to both eliminate low spots, and or cut proper drainage.
but :mad: :mad: :mad: hears what ive found. its to wet to fix the wet spots, but by the time they dry out... theres no need to fix them .....ARG!
there is a particularly shallow swail that holds water and creats a large wet area right in the middle of the area we use often. Its CRYING To be french drained the entire lenght to the back of the property were it drops off.... but i cant dig in the area now as i would just make one HUGE mud hole :mad:
oh well... thats my morning gripe....
/ cant fix the leak when its raining! #2
schmism:
That is the "reasoning" why I took so many years to get a real driveway. Jay
/ cant fix the leak when its raining! #3
First year can be the roughest trying to understand the land,but w/in year you shall get the upper hand.
/ cant fix the leak when its raining! #4
I picked up a couple bundles of little red flags on wire sticks at a home improvement place. They are cheap. I use them for all kinds of things. Mark out the wet areas now and then tackle them when they are dry.
/ cant fix the leak when its raining! #5
Every summer when it is finally dry I am always trying to get about 10 drainage/trail fixes squeezed in...cause there is a limited opportunity to take care of them. Last summer I had spots that never dried out enough.
Make a list and wait til it's dry...that's all you can do!
/ cant fix the leak when its raining! #6
That was good advice about marking the area with flags. 1 X 2's or grade stakes would work, too. Also, a few pictures can help to remember what the problem looked like.
/ cant fix the leak when its raining! #7
So what's your 4x4 for, if it ain't for playing in the mud? Get your camera and get out there man. Tell us how your amazed that your tractor just plowed right through that wet/muddy spot. Then you can tell us how your powerwasher just cleaned it right up. And how your wife is amazed at all the work your little boy toy accomplished.:D :D
well it is, but it only gets you MORE stuck than you would be with out it :D (after all you only managed to get twice as far in because you HAD the 4x4)
/ cant fix the leak when its raining! #9
I have the same issue. I cant wait till the dry season!!! I am in battle with a beat to heck driveway right now
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
New Idea 201 Manure Spreader (A66408)
New Idea 201...
SULLAIR 375H COMPRESSOR (A65643)
SULLAIR 375H...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
2022 EZ-GO ELITE...
