Can't find stump bucket
   / Can't find stump bucket #1
JohnFourteenSix
Kissimmee, FL
JD 3032e, Bobcat T180, Mustang 3003
I'm trying to find a stump bucket available for purchase, but the only one that turns up is the titan one, which seems to be out of stock. Everything else I see is SSQA. Is it simple to convert from SSQA to JDQA? I see there's an adapter plate but it seems that this will cost me some power.
Yes, but that's double the price of the Titan one. I was hoping there would be some other cheaper equivalents! But perhaps my main question is in relation to converting/using a SSQA bucket with JDQA ($675 + $200 shipping)
   / Can't find stump bucket #4
I recently purchased a 36" Stump Bucket for my Kubota L3560.
The tractor hydraulics lacked enough power to withdraw the SB from the ground unless exactly via the insertion path. ( 1,775 pounds FEL lift spec. at the pins.)
I feel confident saying your JD 3032e will not be able to handle a Stump Bucket.
Here is what I bought, then soon sold to a Skid Steer owner:
Skid Steer Rylee ROOT RIPPER Stump Bucket Tree Spade - RRR6X36 - MADE IN THE USA | eBay
https://www.tractorbynet.com/forums...ylee-root-ripper-stump-bucket.html?highlight=
I have had a lot of experience with the Ratchet Rake bucket attachment and a Bucket Solutions' Bucket Spade which led me to believe the SB would work on my Grand L Kubota, but I was sadly mistaken.
Note: we are both working Florida soil.
I'd be mainly using it as a shovel though. Would be loosening the dirt via a subsoiler attachment in the back, and digging it out via the stump bucket in the front. I don't expect to be able to dig in undisturbed ground and get a chunk of dirt. I've also seen "clamp-on" shovels, but those are perhaps too small.
   / Can't find stump bucket #6
Based on my experience I recommend the Bucket Spade.
You work hard for your money. You should spend your money the way you wish.
Are there bigger bucket spades for that?
   / Can't find stump bucket #8
The three volume Bucket Spades are from Titan, Paumco and Bucket Solutions.
The BS/BS is forged and the heaviest of the three.
The Titan and Paumco are pressed steel and/or welded. Unquestionably, the BS/BS is the heaviest and highest quality with very secure attachment to the FEL bucket. BS/BS will tax your Deere PLENTY.
MORE: https://www.tractorbynet.com/forums/attachments/328798-bucket-spade-today-fel-bucket.html?highlight=
VENDER LINKS: Tractor and Skidsteer bucket spade shovel
Quick Spade Combo - Skid Steer Tractor Trencher Loader Bucket / Fork Attachment | eBay
   / Can't find stump bucket #9
Keep in mind you will need at least 650 pounds of Three Point Hitch counterbalance in order to excavate with a BS.
Jeff, thank you very much for all the info! I will sift through it soon!
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2008 Ford Ranger Pickup Truck (A55852)
2008 Ford Ranger...
2016 Ford F-250 4x4 Reading Service Truck (A55852)
2016 Ford F-250...
