can't find part crankshaft ventilation hose MF65 II
   / can't find part crankshaft ventilation hose MF65 II #1
Kisby
Massey Ferguson 65 MKII
Hi I am looking for a replacement breather hose for MF65 MKII. It is the crankshaft ventilation pipe. No 6 in the PDF attached from the workshop manual. I can't find the part or the part number. It doesn't seemed to be listed on any sites. The hose runs between two metal pipes of outside diameter 15mm. Is there a general flexible hose I can adapt??
  • breather hose diagram.pdf
   / can't find part crankshaft ventilation hose MF65 II #2
thats a crankcase ventilation hose . not crankshaft.
   / can't find part crankshaft ventilation hose MF65 II #3
Welcome to TBN.
The part number, 732823M1, is not available. Item 52 in diagram
   / can't find part crankshaft ventilation hose MF65 II #4
   / can't find part crankshaft ventilation hose MF65 II #5
Go to auto parts and get "rubber" breather hose in correct ID to fit pipe and fitting on valve cover....
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A50854)
2007 PETERBILT 335...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Drill Bit attachment (A50322)
Drill Bit...
