can't find part crankshaft ventilation hose MF65 II
   / can't find part crankshaft ventilation hose MF65 II #1
Kisby
Massey Ferguson 65 MKII
Hi I am looking for a replacement breather hose for MF65 MKII. It is the crankshaft ventilation pipe. No 6 in the PDF attached from the workshop manual. I can't find the part or the part number. It doesn't seemed to be listed on any sites. The hose runs between two metal pipes of outside diameter 15mm. Is there a general flexible hose I can adapt??
  • breather hose diagram.pdf
   / can't find part crankshaft ventilation hose MF65 II #2
thats a crankcase ventilation hose . not crankshaft.
   / can't find part crankshaft ventilation hose MF65 II #3
Welcome to TBN.
The part number, 732823M1, is not available. Item 52 in diagram
   / can't find part crankshaft ventilation hose MF65 II #4
   / can't find part crankshaft ventilation hose MF65 II #5
Go to auto parts and get "rubber" breather hose in correct ID to fit pipe and fitting on valve cover....
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
HYDRAULIC PUMP FOR JOHN DEERE 544 WHEEL LOADER (A51244)
HYDRAULIC PUMP FOR...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
Coyote Steel Target (A50515)
Coyote Steel...
