can't find cogged v-belts for marangon disc mower
   / can't find cogged v-belts for marangon disc mower #1
old timer 77
FORD 1100
We have searched and serched for these belts, if anyone knows where we can find any please let us know
thanks in advance old timer 77
   / can't find cogged v-belts for marangon disc mower #2
G'day most bearing supply companies also do a wide range of belts I would be surprised if they could not help you
Jon
   / can't find cogged v-belts for marangon disc mower #3
If you have a number on the belt you might be able to cross reference it using something like Dayco or Gates catalogs. Any numbers? Google is your friend.
SimS
   / can't find cogged v-belts for marangon disc mower #4
With the limited info provided I was able to find out it uses a spbx series metric v- belt. That being said you won't find them on the shelf at any auto or hardware store, a good industrial drive component supply should be able to get them but most likely a special order from Europe.
Best bet is going back to a dealer that supports the mower.
All in all it Looks like a decent mower, good luck with the search.
Just got in and checked replys. What we have is a marangon mdn 210 disk mower for hay use, It has 4 goodyear torque-flex spb 2900 mc v-belts with 2 damaged and the manual witch don't give a whole lot of info says to change all four, we ordered some from v-belts.com hoping they fit, We want to thank bnjodunn,simS winmac for the helpful information they gave, Thanks Have a good evening. old timer 77
   / can't find cogged v-belts for marangon disc mower #6
Why do you need cogged v belts. Do belts have to go around a very small pulley? If not, std v belts will probably work better. A std belt will bulge more as it bends into a pulley. This improves traction/grip.
larry
The manual calls for cogged belts we may have to go the route you suggested. thanks for the reply.
old timer 77
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
