Can't find a house plan
/ Can't find a house plan #41
Re: Can\'t find a house plan
Alan,
The ducting really shuldn't present much of a problem with a vaulted or cathedral ceilings. You can either use sissor truss's or lower the ceiling from the roof a foot or so. It's very common to do this. Usually you just spand the room lengthwise with a gluelam beam and frame off of that. If you want the look of the beam, you frame up on the gluelam. If not, you frame off the bottome. Either way, you get the open span with plenty of space for your ducts, wireing and insulation.
I think your making a mistake by not asking your friend to draw up the plans with you. If he's framing it, than he can come up with the best ways to accomplish what you want based on his experience and knowledge.
Handing him a set of plans drawn by somebody else will force him to spend just as much, if not more time, figureing out how to make those plans work. Especially if he knows a different method to achieve the same result.
On those internet plans, be careful on relying on them too much. Most are just general sketchs and not accurate. If you start adding up the numbers of the room dimentions, you might find that one end of house is longer than the other. Or you might find that a room wont fit in the space provided if you add up all the dimensions. Mechanicals are usually left out too. I think this is done to protect the design and force you to pay $500 to a thousand dollars for their plans. But that' is just my observations and assumptions.
One really good suggestion is to bring pictures from magazines, catalogs and the internet to the person who designs your house. Make sure they know what you like and wnat it to look like. Floorplans are easy. Making it look like your dream is where things get complicated.
Pictures cross all the comunication problems in describing what you like and expect the house to look like.
Every detail that you can provide will save you time and money, not to mention stress and hearthache. Have the exact entryway door picked out. Not close or something like this or that. Make it the exact one! You have to pick it out sooner or later, do it sooner. Same with everything else. The more detail you can provide, the closer to your dream your home will turn out.
Eddie
/ Can't find a house plan #42
Alan,
Eddie
/ Can't find a house plan #43
Eddie, thanks for explaining your position further. Architects can add value even on lower end houses and, while there are exceptions, as a whole, it's certainly not my experience that builders, who aren't trained as designers, can do a better job designing. The best volume home builders employ in-house architects, not builders, to prepare their designs. That's as it should be. Like any other profession though, there's a fair sprinkling of poorer quality architects out there and chances are they're working at the lower end of the market.
Jason, I've come across architects drawings that weren't worth a light too. On occasion, there have also been some pretty hairy disrepancies in mine that I've missed.
On framing, although there are exceptions, most architects are not familiar with the difficulties and practicalities faced on site and a spell working with a hard hat on would benefit them a great deal.
I like your comment about walking in each others shoes. Better buildings result when the designers and builders behave like a construction TEAM. We're all members of that team and we each have a role to play helping it do the best job it can.
/ Can't find a house plan #44
/ Can't find a house plan #45
Man oh man
I just cannot understand it.
This is probably the biggest investment you'll ever make, the most complex puzzle you'll ever take on.
A huge effect on every move you make .
Your HOME!
And you want to cut corners in the design.
Leaving the design to framers is shortsighted. Leave them to their expertise.
Leaving the design to a catalog - some company's draftsman 1,000 miles away that has never seen your lot?
You want a plan where everything is figured out and to get a "firm bid" but on the other hand you want to pay discount or no $ for a draftsman or framer to "design" your home.
90% of my work are homes under 3,000 sq. ft. Actually the smaller the house, the more important the design.
And by design I do not necessarily mean how pretty it is from the curb. I mean is it design effeciently, simply. Does it fit your needs and lifestyle. My job on every house is to determine exactly what you wish for then what you really need. I then attempt to provide as much of the former while delivering the later. A framer does not sit down with you and analyze your needs to try to get the most bang for the buck.
They can most definitely determine the most effecient way to frame a house. But they should not engineer a house or design a house.
The best scenario - one I encourage with my clients - is to get everyone on board from the beginning.
I meet with the client and determine a "program". This could be very complex with many needs and restrictions or could be as simple as adding a 150 sq. ft. bedroom with two windows facing the morning sun" (Or a 400 sq. ft. heated barn for my tractor). I then come up with a quick sketch or two and check with the City for their conditions. Then I sit down with the client and anyone else we can bring in that will be involved in the job. Contractor, framer, concrete, plumber, electrisan, roofer, mother-in-law. I filter everyones input into the final product based on decades of experience.
It is sooo much more cost effiecient to solve the puzzle this way than scratch your head as the carpenter and cabinetmaker "discuss" why things don't fit as the crews are standing by.
If you buy a catalog plan it is not all the detail you will need. i.e. foundation.
If you let people from other trades design your house - you'll get what you desrve.
Poor design lingers long after the sweetness of a cheap price is forgotten.
Also this view of architects as artistic premadonnas that cause costs to skyrocket is myth. 1/10th of 1 percent are the artiste that make headlines with their work. Some neither you or I are eveer going to meet. Most Architects are hard working craftsmen like everyone else building your home.My artistic contribution is that the house flows well, people don't bump into doors, the light comes in the room at the right time, the roof and windows don't leak, the underfloor is not damp, it was built effeciently and within budget with most of your wish list in it, its warm and cozy and everyone just feels comfortable being HOME.
/ Can't find a house plan #46
Man oh man
Your HOME!
/ Can't find a house plan #47
Alan, We are just completing a home as you describe in northern NY.
You want a "waterfront" or "rear view" floor plan, some house plan web sites let you filter the thousands of plans for this option. Or you could sketch it yourself & have a P.E. do the structural calculations. In NYS any plan over 1500 sf needs a P.E. or architects seal.
Any designer or builder should also check www.buildingscience.com for a wealth of free information developed for the US DOE & HUD programs. The information is climate specific which you will need to apply to any pre-drawn commercial floor plan.
/ Can't find a house plan #48
/ Can't find a house plan #49
Find a local architect or designer. Ask for references and check them out. There are not many things worse than going in to a building project without a solid plan.
My wife does landscape design. We had a company going for a few years, doing installations and mods. It was sooo easy to see where people had a defined plan, versus not. It is really important if the project will be done in phases, so all the phases line up properly, are built properly, match in look and feel.
It is better to spend the money up front than to be unhappy with the finished project.
Check those references out. Go look at them. Walk through them if possible. If the designer or architect can't line up some references, pass them up and find someone who can.
/ Can't find a house plan #50
I have my drawing at my office. I'll scan it in and post it tomorrow (Tuesday). The drawing doesn't show doors and windows, just spaces. Very rough. I have put it in Punch software to get some idea of the roofline etc, but the software is not very good and I can't do shed porches or dormers on it. Also can't figure out how to have a second floor in part of the house and a catheral in the other part (in the software that is).
Eddie, I considered using some sort of trusses to give me an "attic" space above the cathedral ceiling, especially to give more room for insulation. However, I need the high ceiling for the loft area, but maybe it won't matter that much. As for insulation once I decided to use foam it became apparent the attic space is not need for that, but would sure come in handy for mechanicals. Heck even electrical could be a big problem with no way to get from one end of the house to the other without drilling through the rafters that are already holding up alot anyway.
I had figured on the gluelam beam with the opposing rafters connecting above the beam.
There will be covered porches front and back so the wiring might could be run in there. However since it is sealed off from the attic, I wonder if it would need ventilation of some sort.
I have read about the high velocity A/C systems but I don't know if the HVAC guys around here know anything about them. What I did read is that they are more expensive.
I have a great respect for professionals like architects, and the value of their services. No question whatsoever that I would use one for the whole project if I could afford it. We are talking about a budget of $170,000, which is about $85 per square foot. We already have a septic and well and the land, so this is strictly the house. Looks like we are losing our rock already in favor of brick because of cost, and granite countertops are on the way out. But I am steadfast on high quality energy efficient windows and doors, foam insulation, 3 A/C zones, and metal roofing. If I spend alot on an architect I will have to cut the square footage back .
Really the plan is simple and rectangular. From the front you would see a 12/12 roof - gable on the ends, with shed porch, the garage on the left side would be a lower roof, same pitch. Inside the front door is a 24 by 18 great room with stairs to loft on the left, kitchen to the left of the stairs and dining area on the back left. All of this open, with a loft area plus guest bedroom above the kitchen & dining area. Master suite to the right, about 16 by 34 altogether. To the left of the kitchen/dining between those rooms and the garage is the mud room, about 8 by 24. In the back of the house more shed porch with a large area that will be shaded from the southwest, were the hot sun comes from in the summer.
Here in north Texas, you have to stay away from lots of windows and use as few windows as possible on the west/southwest. Many of the windows will be under porches. The biggest exposure to the hot sun will be on the right which is southwest, this is the master suite. Mrs. Alan L. insists on having the windows, so they must be very sun resistant glass.
We want an unpretentious home in a rural setting. We do not want something that looks like it belongs in the middle of a Dallas development.
We plan to use lots of cedar under the porches and soffits.
Well I got tied up and didn't get to scan my plan today. Maybe tomorrow. See, this is why I can't seem to get it done. No time!
/ Can't find a house plan #57
Alan,
My brother in law is a Mchanical Engineer who owns a HVAC design business. He is the one who the arichitects go to to get HVAC engineering plans. You might want to find a HVAC Engineering company, give them a call and ask them about pricing. The HVAC Engineeers are already going to know all about the different types of windows, especially those that are used in your area as they are designing to those specs, in other words designing HVAC systems around localy used and built building components. Also a HVAC Engineeer is gong to tell you how high up to build your porches and how wide to go. They are going to know all about the summer sun being higher than the winter sun etc. etc. and he calculations to provide nice light in the winter but shade in the summer. I also like the idea of another poster of getting a P.E. Structuaral engineer to draw up the house plans. Perhaps locate a good P.E. and have a meeting with the P.E. and an insulation contractor. Actually doens't this all sound like exactly what an architect does? Just as you have subs to sub out on their specialties for the actual construction, you could sub out the engineering work and perhaps get what you need. The only way to know that is to call some engineeers and ask about their services and pricing. I would say after you have made those phone calls you will know what directin to take.
/ Can't find a house plan #58
Alan,
Here's a rough sketch. I had a devil of a time getting it under 100K.
UNUSED IRANCH 38" MINI ROCK BUCKET (A60432)
UNUSED IRANCH 38"...
BUNDLE OF 13'-1 1/2" PURLINS (A60432)
BUNDLE OF 13'-1...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
(INOP) JOHN DEERE 240 SKID STEER (A60430)
(INOP) JOHN DEERE...
