Can't decide on which Kubota...
   / Can't decide on which Kubota... #11
Re: Can\'t decide on which Kubota...
The 990 will cut 4 ft grass - just doesn't leave a perfect finish. But you can cut it again when it gets back to 18" tall and the results are quite good. Don't know about the bats - but <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showprofile.pl?Cat=&User=gatorboy&what=showmembers&page=1> gatorboy</A> (David Hoffman) has a Kubota M8950 and a Rhino 15 foot bat - maybe he'll see this.
Also, I think John Miller III knows something about the M6800 and an 84" Brown rotary.
   / Can't decide on which Kubota... #12
Did you get your tractor?
I chose the M6800 over the M5700 or `M4900 because the front axle is much more beeefy. Also liked the front locking differential.
The one comment I have about the tractor is that it is light. That is OK for now because it is just light enough that I can still use my trailer for it. Any more and I'd be giving up my
galvanized lowboy for a painted gooseneck. The M6800 has bigger tires which = more surface area + = less ruts in pastures + = more room for ballast water. For now I don't use ballast, but plan on adding ballast when I get a loader.
The wider tractor also means if you buy a box blade you will need a wider one to cover the tracks. 77" for M6800 with rear tires in closest position, and 84" if the tires are out one setting.
My M6800 and one other I hnow of had a problem with popping out of second gear when going up a hill. It is the non-hydraulic 4WD model. Kubota did a top notch job of fixing it no charge.
The hydraulic shuttle is a little hard to modulate the clutch for small movement, but I think the clutch is the weakes thing in the whole tractor, so if you can live with an ON-OFF clutch it probably will last longer.
I know this tractor well. email me if you have questions.
   / Can't decide on which Kubota... #13
Gus,
What is this Ag tractor/machinery forum you refer to??
TBone
   / Can't decide on which Kubota... #14
I purchased a M6800HD this summer with much help from this forum and jrpoux in particular. I am very happy with the purchase and I am quickly closing in on my 50 hr service. My observations:
1) M6800 is unquestionably the best bang for the buck M-series at the moment.
2) The forum (and friends) had me very concerned about going non-Hydro/too big but I felt I needed more size/power than a Grand L and my gut was correct on this.
- Choose hydraulic shuttle for loader-type work or standard shuttle for straight-line work. I got the hydraulic shuttle and like it.
- Remember: all Kubotas are light for their power. I bought this tractor as much for the size as the HP.
- I was able to out-dig a Case 580E in a fairly well compacted soil stock-pile! The Case had more bucket capacity but couldn't get a decent bite. (LA1162 loader).
Have fun with your decision if it has not already been made!
EdK
SUV (A59231)
SUV (A59231)
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59575)
1997 DORSEY...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
2018 HINO 268 24FT NON CDL REEFER BOX TRUCK (A59575)
2018 HINO 268 24FT...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
