can't call it work anymore
/ can't call it work anymore #1
LedgeFarmer
Kubota L5740 HST Cab
Greetings forumites. I was told that as soon as my new tractor arrives that I should post some pics, so here they are. L5740 HST cab with HD round back QA bucket. I also got a 6' Eagleline road grader, HLA 2k lb. QA forks, 75" Meteor pull type snowblower, Valby 6" chipper, 9" post hole digger, and a dump trailer. Most valuable option so far is the REI radio. Can't really call it work anymore.:D
/ can't call it work anymore #3
Great looking tractor. You're going to have some fun with that:thumbsup:
Charlie
/ can't call it work anymore #4
Greetings forumites, I like that. You did good with the pictures.
Good luck with your new tool(s)
/ can't call it work anymore #5
Congrats, looks like you are pretty well set up!:thumbsup:
James K0UA
/ can't call it work anymore #6
Welcome!
That's quite a nice tractor & set of implements you got there!
/ can't call it work anymore #8
Yep, that is a really nice tractor for sure. If I ever wear my L5030 out, I will probably buy one of those.
As to the "work" part, I spent 7 straight days on our L5030 HSTC and M8540 HDC last summer and trust me, even with air, radio etc., it can still turn into work.:laughing:
/ can't call it work anymore #9
A/C, shade, tunes, cushy seat, pressing buttons & moving easy-to-move levers ... Where's the work??! Were you getting out of the cab a lot???!
/ can't call it work anymore #10
Well, I was crawling out of one tractor an into another, but we were mowing levies in addition to some stuff that was over the cabs and I was always twisting about to make sure I wasn't tearing my mirrors off, running into a gully or digging myself out of a gully when I couldn't see it; backing into stuff, dodging stobs and constantly turning the steering wheel, raising/lowering the cutters and hanging onto the uphill rails to stay in the seat; raising/lowering the FELS to keep from digging in at the bottom of a hill and to act as a counter balance on the way up.
Now it was easier than our old open station tractors, but getting up and doing that for seven days straight even in cabs still turns into work.:laughing:
Of course me being an old geezer may have had something to do with it; not sure.:eek:
/ can't call it work anymore #11
That is a very nice tractor and an impressive list of equipment. Do you mind if I ask you an off topic question? I noticed the clear panels on your barn roof. How long have you had them and are you happy with them?
thanks,
/ can't call it work anymore #12
thanks,
Hopefully OP will respond, too, meantime: My dad's barn has 3 or 4 of those type panels, fiberglass. They let in good light but get brittle & crack, worn out long before the metal roofing surround them. If you're OK with replacing them when needed, then go for 'em :thumbsup: If you install them at the top, so their top edge is under the ridge cap, you'll have to remove the ridge cap & some nails/ screws along the edge of the overlapping neighbor metal panel .. along with all the nails/ screws securing the clear panel itself. Not too big of a deal, unless the roof is really steep, i.e. about 6/12 or steeper.
thanks,
Barn was built 2 years ago. I am told the new clear panels will last as long as the metal ones with very little change in color / translucency, but time will tell. I love the natural light though.
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
