3-Point Hitch Cannot engage PTO
   / Cannot engage PTO #1
TVZ
MF 1726E
I have a Massey Ferguson 2018 MF 1726E. I cannot engage the PTO. The lever will not go forward to engage it. Down below, I see this (attached). IMG_0514.JPG
It looks like that bolt-like object could be turned in or out. Is that what I should try doing?
Thanks.
   / Cannot engage PTO
I have a Massey Ferguson 2018 MF 1726E. I cannot engage the PTO. The lever will not go forward to engage it. Down below, I see this (attached).View attachment 665045
Thanks.
Does anybody know if there is some kind of adjustment that might be needed to allow me to engage the PTO?
   / Cannot engage PTO #3
That’s just the switch to keep the tractor from starting with the PTO on.
   / Cannot engage PTO #4
Perhaps a dumb question, but have you first engaged the appropriate PTO speed (540 or 2000) lever?
   / Cannot engage PTO
Thnx for the response, Irvingj. However on mine I believe there is only one lever/switch associated w/ the PTO--on the floor on the right side.
It must be in the "N" position (to the left in this photo) in order to start the tractor. However I cannot move it to the "540" position, whether the tractor is running or not.
   / Cannot engage PTO
Ok, I finally went at it w/ a giant screwdriver and was just able to pry the lever forward. So I then sprayed the heck out of it from above and below w/ WD-40, and it gradually loosened up!
   / Cannot engage PTO #7
It's surprising how fast some of those levers will freeze up -
use it his time, works fine, a couple of weeks later, locked
   / Cannot engage PTO #8
Sorry, my bad -- apparently the 1726 is NOT a SCUT. (My 2310 has a 2000 RPM mid-PTO as well as the rear 540 one.)
In any case, glad you got it fixed! And yes, what tookielee said - get some permanent lube in there. I always treat WD-40 --which works wonders in some situations, for sure-- as a temporary solution.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
Giyi 43" Disc Mulcher (A57149)
Giyi 43" Disc...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2018 Chevrolet Silverado 2500HD Crew Cab Service Truck (A56858)
2018 Chevrolet...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
LOT OF RIDGE ROW TIN (A58374)
LOT OF RIDGE ROW...
