Candies for B3030
   / Candies for B3030 #11
Stef, Unless the part numbers are different, I have a step aid that came standard with the 3030 cab model and the 72" MMM. There appears to be no clearance issue between the step and the MMM.
   / Candies for B3030
Mike_C, if you want more detailed pictures just let me now. /forums/images/graemlins/wink.gif
   / Candies for B3030
bwvfan, the cab model is not the same thing at all. The steps are not the same. You can get on a B3030 easily without a step aid, but it would be much more difficult to do the same with a cab model because you have less room to move.
   / Candies for B3030 #14
Stef,
Can you tell me where you found the breakdown of that area? I have the 2630 but Im pretty sure the operator area is similar. I would like to look at some other 26 and 3030 but the dealers here just dont seam to keep any on the lots. Thanks, Jim
   / Candies for B3030 #15
Thats a cool step.....now I have to get one /forums/images/graemlins/laugh.gif
Update: Ordered it... /forums/images/graemlins/grin.gif
   / Candies for B3030 #16
Stef,
Did you put a step on each side? I don't do it very often, however sometimes I do dismount the tractor on the right side. With your remote loader stick, that might be difficult though. Are the step(s) you bought already painted Orange #2?
   / Candies for B3030
3030PJ, the step aid is only available for the left side and yes it's already painted orange. You buy it, you open the box, you bolt it (around 2 minutes maybe) and you're done. That's all you have to do.
You cannot be disappointed about that option, it's impossible.
   / Candies for B3030
Devildog, try this link:
B3030 parts list PDF file
It's a PDF file so you need Acrobat Reader to open the link. The web site of this file is:
TractorSmart B3030HSD web link
I've never found a link for a B2630 or one for a B3030cab but I think that you'll find it interesting anyways because the two tractors are very similar if not the same for a lot of parts.
   / Candies for B3030 #19
I also bought the step for my B3030 back in May. For those that are wondering, it says it wont fit on the tractor with a MMM. I figured it was cheaper to by the Kubota step and shorten it to clear the MMM than it was to build one from scratch. To my surprise, the step does clear my 72" MMM when its all the way up and pinned. (only about 1/4" of clearance) Of course you don't need the step with the MMM on because it has a step, but it does come in handy when the MMM is off, or when the front rotary broom is on.
   / Candies for B3030 #20
Thanks Stef, I was looking through that parts list and noticed a few small items I was missing but the main thing that caught my eye was the auxiliary control valve and how it mounts with the lever and a different cover you can get where the lever mounts. I wonder if that can be used for a TNT option? Jim
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2019 FORD F-350 SERVICE TRUCK(INOPERABLE) (A50854)
2019 FORD F-350...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2019 FORD F250 (A50854)
2019 FORD F250...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
