Backhoe Can you run backhoe on bx18?
   / Can you run backhoe on bx18? #1
cavaselis
I dont need the 22 or 23 hp?Could you even run it on a bx15?
Thanks
   / Can you run backhoe on bx18? #3
First off, just so the models aren't confused, there is no BX15 or BX18. There used to be a BX1800 which has been replaced by the BX1830; each has an 18 hp engine, but less hp at the PTO. The BX1500 has a 15 hp engine and less hp at the PTO. The BX2200 was replaced by the BX2230; each has a 22 hp engine with 16.7 hp at the PTO. The BX22 had a proprietary front end loader and backhoe attached; it was replaced by the BX23. Each of these has a 22 hp engine with 16.7 hp at the PTO. (To date, "BX" followed by 2 digits indicates that the tractor comes with a proprietary backhoe; "BX" followed by 4 digits does not.)
In the class of tractors known as sub-compact utility tractors (sub-CUT), there are 3 which have proprietary backhoes: Kubota BX23, Massey Ferguson GC2310, and Cub Cadet 5234D (CC also has 2 gasoline versions). Also in this class and engine size, but without backhoes are the John Deere 4010 and New Holland TZ24DA. (All 5 manufacturers also have models with less hp, but no bh.)
There are several 3 point hitch backhoes which CAN be attached to this class tractor, BUT there is a consensus that they work poorly for a multiplicity of reasons.
Last week Woods released its Groundbreaker X BH6000, a subframe mounted bh designed for this class tractor. Wallenstein is said to be developing one as well. (I am not certain whether the Wallenstein is a completely new backhoe or whether they are taking an existing model and are developing a new sub-frame for quick attach to the sub-CUTs.) There has been much heated discussion on this board as to how well these units will work. MANY of us here have been waiting for some time for these unit to come out and we still are waiting quite anxiously for the first reports to trickle in from fellow TBN'ers as to how well either one actually works.
I have not heard of the Woods unit being able to work with the BX1830. In the post above, Neil Messick says it will. I assume that Neil is basing this statement solely on Woods specs. that the bh is for 18-24 hp tractors. Supposedly, Woods' engineers tested it out on a number of different sub-CUTs. None of us on this board has yet purchased one of these units, tested it, then come back here to report about it. I'm considering one for my BX2200; many of my fellow TBN'ers advise strongly against it. There is no way I would consider attaching a bh to one of the 18 hp units. Perhaps it would work in a sand dune, but I just cannot see how it would have enough power to dig in more normal conditions. I have harder than average soil and I'm nervous about even the 22 hp tractor being able to power a bh in my soil. Even if I had softer soil, I would not personally consider anything less than a 22 hp tractor for this (even though it is small) backhoe.
I'd strongly suggest that you go back to the archives on this board and read the threads about sub-CUTs and backhoes and read as much as you can elsewhere before making any decision. It would be sad to invest multiple thousands and then discover that it didn't work. /forums/images/graemlins/confused.gif You may want to do what many others of us here are doing-waiting for reports to show up on this board!! Good luck with your research and decision.
P.S. Here is a link to the most recent thread. As you scroll down through it, you will find links to two earlier and longer threads. All have much food for thought.
Woods bh for BX's
   / Can you run backhoe on bx18? #4
I would think that the backhoe would work equally as well on an BX1800 as BX2200. Isn't the backhoe performance primarily determined by the Hydraulic pump flow and pressures? If so they have the same exact pumps actually the BX1500 does as well I think.
Granted there would probably be some difference in load on the load to the engine during running, but if I understand what others with BH have said they typically don't run at full throttle when using the BH.
Again, I don't know this as fact, just suspect this would be the case.
As for working on any of these, Kubota does not recommend them thus I would assume they would be unauthorized attachements, so I would also assume that any warranty work relative to possible damaged caused from the BH would run the potential of being denied.
So if it were me, I would first look at trading in for a BX22/BX23 or wait until warranty was not an issue and take my chances if the cost difference was too great to trade.
Good luck and keep us all posted if you decide to try one of these on your unit.
I did see my local dealer had a Land Pride mounted to a BX2230 a month or so ago, but I drove by there today and did not notice the unit on the lot.
   / Can you run backhoe on bx18? #5
Land Pride "what"?????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Can you run backhoe on bx18? #6
Sorry Junkman, should have said Backhoe.....guess nobody else reads minds either /forums/images/graemlins/grin.gif
   / Can you run backhoe on bx18? #7
</font><font color="blue" class="small">( I...think...the backhoe would work equally as well on an BX1800 as BX2200. Isn't the backhoe performance primarily determined by the Hydraulic pump flow and pressures? If so they have the same exact pumps actually the BX1500 does as well I think. Granted there would probably be some difference in load)</font>
O.K., that makes sense. I would guess that a smaller engine with less output could build up the same pressure but that it might take longer time for the pressure to build. So on breakout in hard soil it might take longer for the bucket to break a hard chunk of material away from the substrate. As you imply, this could be compensated for by running the smaller engine at higher RPM. You make some good points! Anyone out there ever run a bh on an 18 or 15 hp tractor?
   / Can you run backhoe on bx18? #8
</font><font color="blue" class="small">( Sorry Junkman, should have said Backhoe.....guess nobody else reads minds either /forums/images/graemlins/grin.gif )</font>
I wasn't aware that Land Pride was making a backhoe attachment for the BX series tractors. I was under the impression that Woods was the first manufacturer to offer a aftermarket backhoe that was sized for the Kubota BX. That is what prompted my question.
   / Can you run backhoe on bx18? #9
I had posted this in one of the other backhoe posts, but here is the link to the landpride site and I think this is the one that was on the BX2230 I saw at my local dealer in May.
Landpride Backhoe
I don't think anyone commented much on this unit so I assume nobody has any knowledge or experience much with it, but thought I would throw it out as I saw it mounted so I took a quick look compared to the BX23 and like the fit and finish better with the 23, but for many like myself the aftermarkets do potentially offer an option besides upgrading the tractor (which I would rather do if I could justify a backhoe /forums/images/graemlins/grin.gif)
   / Can you run backhoe on bx18? #10
SURFRAN,
The stats. on your link page don't give the weight. I couldn't tell what model JD it's on but it looks like a small CUT, not a subCUT. How big did the unit look? The stats page said it connects to the 3ph but some frame kits are available; any idea whether it was attached to the BX by 3ph alone or by sub-frame? Also, do you know whether it's powered by the tractor's hydraulics or if it has its own hydraulic pump powered by the PTO?
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2014 Nissan Frontier Pickup Truck (A50323)
2014 Nissan...
KMC KELLEY 3374 PORTABLE PEANUT COMBINE (A51243)
KMC KELLEY 3374...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
JOHN DEERE 2840 TRACTOR (A51243)
JOHN DEERE 2840...
