First off, just so the models aren't confused, there is no BX15 or BX18. There used to be a
BX1800 which has been replaced by the
BX1830; each has an 18 hp engine, but less hp at the PTO. The
BX1500 has a 15 hp engine and less hp at the PTO. The
BX2200 was replaced by the
BX2230; each has a 22 hp engine with 16.7 hp at the PTO. The
BX22 had a proprietary front end loader and backhoe attached; it was replaced by the
BX23. Each of these has a 22 hp engine with 16.7 hp at the PTO. (To date, "BX" followed by 2 digits indicates that the tractor comes with a proprietary backhoe; "BX" followed by 4 digits does not.)
In the class of tractors known as sub-compact utility tractors (sub-CUT), there are 3 which have proprietary backhoes: Kubota
BX23, Massey Ferguson GC2310, and Cub Cadet 5234D (CC also has 2 gasoline versions). Also in this class and engine size, but without backhoes are the John Deere 4010 and New Holland TZ24DA. (All 5 manufacturers also have models with less hp, but no bh.)
There are several 3 point hitch backhoes which CAN be attached to this class tractor, BUT there is a consensus that they work poorly for a multiplicity of reasons.
Last week Woods released its Groundbreaker X BH6000, a subframe mounted bh designed for this class tractor. Wallenstein is said to be developing one as well. (I am not certain whether the Wallenstein is a completely new backhoe or whether they are taking an existing model and are developing a new sub-frame for quick attach to the sub-CUTs.) There has been much heated discussion on this board as to how well these units will work. MANY of us here have been waiting for some time for these unit to come out and we still are waiting quite anxiously for the first reports to trickle in from fellow TBN'ers as to how well either one actually works.
I have not heard of the Woods unit being able to work with the
BX1830. In the post above, Neil Messick says it will. I assume that Neil is basing this statement solely on Woods specs. that the bh is for 18-24 hp tractors. Supposedly, Woods' engineers tested it out on a number of different sub-CUTs. None of us on this board has yet purchased one of these units, tested it, then come back here to report about it. I'm considering one for my
BX2200; many of my fellow TBN'ers advise strongly against it. There is no way I would consider attaching a bh to one of the 18 hp units. Perhaps it would work in a sand dune, but I just cannot see how it would have enough power to dig in more normal conditions. I have harder than average soil and I'm nervous about even the 22 hp tractor being able to power a bh in my soil. Even if I had softer soil, I would not personally consider anything less than a 22 hp tractor for this (even though it is small) backhoe.
I'd strongly suggest that you go back to the archives on this board and read the threads about sub-CUTs and backhoes and read as much as you can elsewhere before making any decision. It would be sad to invest multiple thousands and then discover that it didn't work. /forums/images/graemlins/confused.gif You may want to do what many others of us here are doing-waiting for reports to show up on this board!! Good luck with your research and decision.
P.S. Here is a link to the most recent thread. As you scroll down through it, you will find links to two earlier and longer threads. All have much food for thought.
Woods bh for BX's
