Can you ID this farm implement?
/ Can you ID this farm implement? #1
gwfami
1969 JD 4020
Hi,
We have had this on our farm since the 1960's, when I was just young. I'm pretty sure that it's an Eversman automatic land leveler that telescopes, but there are no readable id marks on it. Since I am the last of the clan, I don't have anyone to ask about it. It's going to be auctioned off with the rest of our farm equipment so I'd like to know what it is, as google hasn't been a great friend in this case.
Thanks,
gwfami
/ Can you ID this farm implement? #2
Definitely a land leveler - like a road grader. Brand - ??
/ Can you ID this farm implement? #3
They used to be called a land plane, they where common in flood irrigation country to get a field level before planting and corrugating for irrigation using siphon tubes out of ditches and gated pipe.
You couldn't have any high or low spots or your water wouldn't go where is was desired.
Usually the box blade was more in the middle some would even have a blade shaped similar to a wing behind the wheels to help in compacting and leveling a field while maintaining the required slope for the water to flow/
Thanks,
We used it to work our roads and pipe irrigated land (not siphon tubes, but irrigation pipes). Any idea what brand/model it is? This particular one could hydraulically telescope to make it longer/shorter as you desired. A friend thinks they have found an additional extension to make it even longer in a weedy part of the land.
Google doesn't show anything like this with the roller in front and the ability to telescope.
/ Can you ID this farm implement? #5
The only one I was familiar with was eversman they had several models.
Know of any pictures/history or that sort of thing? I'm not finding much on eversman online.
/ Can you ID this farm implement? #7
Not really, sorry
Thanks,
I haven't run across any eversman telescoping levelers, and the patent provided by mxg342 seems to be almost identical to my leveler, but the patent was assigned to Case/IH, so I have contacted the Case/IH archives to see what they can find. In one of the pictures of the side, if you squint just right, you can see something like "International".
/ Can you ID this farm implement? #12
We had one very similar on the farm. We called it a land plane. Every summer, when the crops were laid by, we would take in 100 acres or so more farm ground. We would cut the timber off, use the dozer to push up stumps, then the fun begin picking up stumps and roots by hand. No grapple in those days!
Then we would use the land plane to level the field. It did a wonderful job when operated correctly.
I got one of my worst whippings from my dad running that thing one year. I made a mistake that I never made again, that is for sure! Funny thing is that is the day I learned how to weld too. It had to hold or another whipping was coming! :laughing:
Thanks for the memory. :shocked:
/ Can you ID this farm implement? #14
This just posted on Minneapolis Craigslist.
/ Can you ID this farm implement? #16
There's a great picture of it and a description too on that press release.
/ Can you ID this farm implement? #17
I remember we borrowed one once on the farm when I was a kid. To level out a small area of the field where water would run off too quickly. I remember it being very similar to this, but over the blade it had a large pendulum that would swing from side to side indicating level. But I was very small, probably 9 or 10 years old.
/ Can you ID this farm implement? #19
Yeah, they don't turn up in google searches very easy, so maybe weren't too common. Hard to find any info on them at all.
2018 Kubota SVL 75-2 Skidsteer (A65579)
2018 Kubota SVL...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2017 John Deere X570 Riding Mower (A66408)
2017 John Deere...
Bradco 8611X Backhoe Attachment (A65579)
Bradco 8611X...
2022 EZ-GO ELITE...
