Rotary Cutter Can you help me identify this roraty cutter?
   / Can you help me identify this roraty cutter?
Thanks 5030. I have the cover. Just had it off to remove the blades. I've sent an inquiry to Woods.
   / Can you help me identify this roraty cutter? #12
I purchased this 3pt rotary cutter to convert to hydraulic drive for my skid steer.
Many thanks!
Can't help with identification, but here is a unique skid steer rotary cutter for some design ideas.
The hydraulic motor has a built in cushion valve to let the blades spin down quickly when the hydraulic flow stops.
Note the front wheel and the hinged SSQA mounting:
That's cool. Thanks for the ideas.
Thanks everyone! I got more aggressive with the bolt, assuming it was RH thread and was able to break it loose. (Used the same 4ft cheater I had on it 3 weeks ago, but this time it gave-in. I think it knew I was chatting with you guys!)
Got the blade carrier off and made my way down to the seal. Seems to have a number on it - 7989. Now I just need to find where to get a replacement and instruction on how to replace it.
   / Can you help me identify this roraty cutter? #15
I ordered mine from messicks
DYNAPAC CC5200VI DBL DRUM ROLLER (A52707)
DYNAPAC CC5200VI...
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
INGERSOLL RAND  G25 GENERATOR (A55745)
INGERSOLL RAND...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
