Rotary Cutter Can you help me identify this roraty cutter?
   / Can you help me identify this roraty cutter?
Thanks 5030. I have the cover. Just had it off to remove the blades. I've sent an inquiry to Woods.
   / Can you help me identify this roraty cutter? #12
I purchased this 3pt rotary cutter to convert to hydraulic drive for my skid steer.
Many thanks!
Can't help with identification, but here is a unique skid steer rotary cutter for some design ideas.
The hydraulic motor has a built in cushion valve to let the blades spin down quickly when the hydraulic flow stops.
Note the front wheel and the hinged SSQA mounting:
That's cool. Thanks for the ideas.
Thanks everyone! I got more aggressive with the bolt, assuming it was RH thread and was able to break it loose. (Used the same 4ft cheater I had on it 3 weeks ago, but this time it gave-in. I think it knew I was chatting with you guys!)
Got the blade carrier off and made my way down to the seal. Seems to have a number on it - 7989. Now I just need to find where to get a replacement and instruction on how to replace it.
   / Can you help me identify this roraty cutter? #15
I ordered mine from messicks
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2013 PETERBILT 367 TRI-DRIVE WET KIT (A55745)
2013 PETERBILT 367...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A55745)
WHISPEREATT 25...
2008 CAT D6T DOZER (A55745)
2008 CAT D6T DOZER...
FORKLIFT MANLIFT BASKET (A55745)
FORKLIFT MANLIFT...
