Can you come help me mow
   / Can you come help me mow #1
chucko
Polk Co , Fl
bx1800
I get a call for Sis and BIL who took on a mowing job that was too much for their mower and wanted me to come help with my bota. This is what I found when I got there.
   / Can you come help me mow #2
I wouldn't even want to do that with my BX without the rotary cutter. It will do it, but I sure hate to.
   / Can you come help me mow #3
Looks like a lot of work for the mower operator, a lot of head turning, paying attention to where you are at, avoiding all those obsticles, type of job....
   / Can you come help me mow #4
I agree, not a job for a mower, but more for a rotary cutter to knock it down first then maybe and that is just MAYBE run back over it with a mower. Even then the surplus growth will tax the belts on a mower, although some of the better ones will go thru it with no problems. I would probably attempt it with my Steiner 525 as it has plenty of power, good belt setup, and hydrostatic so I could creep into some of the thicker bunches without overloading the mowing deck. Still could be a problem with hidden items, that a rotary cutter would take in stride (and throw across the yard). Layering the cuts, first high and then lower when you can see might be a smart move, but requires double cutting.
If you have already done this, and didn't tear up anything, good job!!!
David from jax
I gut with the deck set to "top" and it was really still too much. I will not be doing that again
   / Can you come help me mow #6
I wouldn't either. It amazes me what these BX's will cut, but that sure is pushing the envelope.
   / Can you come help me mow #7
Agreed - rotary cutter...or as I called it growing up on the farm in KY... a bush hog. I have mowed many times through stuff like that with our old bush hog but not a finish mower. That would be slow going.
   / Can you come help me mow #8
IMO that needs to be bush hogged one week, flail mown the next week or two, & then finished mown in another week or two.
   / Can you come help me mow #9
You can bush hog/rotary cut that just fine. Just use the right tool at the right speed for the right job.
   / Can you come help me mow #10
Should be done by now then. With the mmm you just need to go over the tall stuff twice.
larry
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
