Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ?
   / Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ? #1
ebri
Mustang 2040
Is it OK to switch from 10-16.5 skidsteer tires to 12-16.5 tires but mount them on my 10-16.5 wheels ?
I have a Mustang 2040, looking for a taller tire for a bit more speed. Thank you
   / Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ? #2
My case 1840 skidsteer has 12x16.5 tires where 10x16.5 tires should be hard to change since they are near new. BUT the 12x16.5 tires makes grading harder because the bucket is not flat on the ground like they would be with the smaller tires, something to think about.
Hadn't thought of that, so thank you. This is a snow plow machine and I need a bit more speed . I'm going from a 30" tall tire to a 33.
   / Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ? #4
as mentioned above bucket level and flat is a issue, we had a 743 Bobcat someone had taller filled tires on, we switched to regular and the fix they had was weld a piece of 1 1/2 thick steel on the arm stops,
Forks (A49251)
Forks (A49251)
2013 Mitsubishi Fuso FEC92S Rear Loader Garbage Truck (A46683)
2013 Mitsubishi...
Ford 631 2WD Tractor (A49251)
Ford 631 2WD...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A48836)
1996 International...
2014 Dodge Journey SXT AWD SUV (A48082)
2014 Dodge Journey...
10-16.5 FR SKS1 Tires on Wheels (A49251)
10-16.5 FR SKS1...
