Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ?
   / Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ? #1
ebri
Mustang 2040
Is it OK to switch from 10-16.5 skidsteer tires to 12-16.5 tires but mount them on my 10-16.5 wheels ?
I have a Mustang 2040, looking for a taller tire for a bit more speed. Thank you
   / Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ? #2
My case 1840 skidsteer has 12x16.5 tires where 10x16.5 tires should be hard to change since they are near new. BUT the 12x16.5 tires makes grading harder because the bucket is not flat on the ground like they would be with the smaller tires, something to think about.
Hadn't thought of that, so thank you. This is a snow plow machine and I need a bit more speed . I'm going from a 30" tall tire to a 33.
   / Can we mount 12 16.5 skidsteer tires on 10 16.5 wheels ? #4
as mentioned above bucket level and flat is a issue, we had a 743 Bobcat someone had taller filled tires on, we switched to regular and the fix they had was weld a piece of 1 1/2 thick steel on the arm stops,
2024 Ford F-150 XL (A44500)
2024 Ford F-150 XL...
2019 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A44571)
2019 International...
2009 IC PB10500 School Bus (A42742)
2009 IC PB10500...
2020 Ford F-150 XL (A44501)
2020 Ford F-150 XL...
Liebherr LR 621B (A42021)
Liebherr LR 621B...
2020 XCMG CV123PDU VIBRATORY ROLLER SN:AKJE05973 powered by diesel engine, equipped with EROPS, a... (A40019)
2020 XCMG CV123PDU...
