Can the hydraulic system get air locked after a fluid change
   / Can the hydraulic system get air locked after a fluid change #101
Look. Let's back up & try to unconfuse things a bit. The problem is the OP has done a hydraulic oil and filter change and now his hydraulic pump is not moving fluid. So in his original question in the title of this thread the he asks,
"Can the hydraulic system get air locked after a fluid change"​
The answer is that in an open center hydraulic system like his Kioti and most small tractors use, the hydraulic system cannot get air locked because it is not a sealed system. The sump is always open to the atmosphere by way of the vented sump. Hydraulic fluid cannot get "air locked" because one end of the circulation is open to the atmosphere. Any air gets moved along - or not - to the sump and escapes to the atmosphere. That's not to say that there can't be trapped air in the system causing other effects, but it won't cause an "air lock".
An "Air Lock" is not why his pump isn't working.
BTW, the radiator and cooling system are different.
Modern tractor cooling systems ARE SEALED SYSTEMs. They are not open to the atmosphere unless the system overheats. They definitely do have to be purged of air during filling because once the radiator cap is tightened down that system is sealed. It is not open to the atmosphere, so with the radiator cap in place there is no way for air to escape. In a sealed cooling system a trapped air pocket doesn't always mean the entire flow is blocked, but it can be. It will create a "hot spot". So there definitely are ways that an air lock can cause heating problems in a sealed system.
Hope this helps,
rScotty
I read his first post as the HST pump is the problem.
Another on my list of why I won't buy a tractor with HST.
Trouble shooting section
   / Can the hydraulic system get air locked after a fluid change #103
Leonard, can you give us a recap on what are exactly the issues you're experiencing? The thread got slightly all over the place, so there is probably more confusion now than before.
The tractor will move forward and reversefor a short distance and then it is like it is in neutral. Rocking foot pedal back and forth a couple times and it will move again.there is a noise like a stomach growling and then it starts to move.
Today I removed wheels,fenders,floor boards etc to be able to get a better look. I found the pressure test ports and relief valves. Ordered a hydraulic pressure tester from amazon.I also found a couple of things I wasn't aware of. A small leak in the remote hydraulics but only when they are activated. The tractor has a form of cruise control and the lever to activate it does nothing.where the linkage enters the housing seems to be seized.I don't know if this could have anything to do with the problem.Any input much appreciated.Thanks,Len
   / Can the hydraulic system get air locked after a fluid change #106
Not at all unusual for remotes to leak when they are activated. The problem is when they are activated one of the remote hoses holds pressure - but without a remote implement there is no pathway for fluid back to the sump. A leak there doesn't mean a problem. Try working the control lever for the remote while the engine is off. Sometimes that will release trapped pressure. Or look up hydraulic coupler pressure relief tools. Some just use a light tap wit a hammer and a rag on the coupler end.
I don't know exactly how that linkage to the cruise control works on yours. but it sure sounds suspicious. I'd definitely work on that and get it right. That could be the problem.
By the way, congratulations on removing parts and also getting a set of guages ordered. We can use another hydraulics guy on TBN.
rScotty
Thanks Scotty ,I'm supposed to get gauges by Saturday.I'll keep you posted. The cruise control linkage is mechanical I'll fix it but not sure it could contribute to my problem?
The leak in the remote tube was at the but not the coupler. I tightened it and stopped that leak. The main hydraulic filter seems to be leaking very slightly. I cleaned it completely and checked it after a couple hours and it was wet.
   / Can the hydraulic system get air locked after a fluid change #109
I'm not sure either. But at least it is in the right system. What did you ever figure out on the Kioti clutch? Does it have one? If so, can it be locked or adjusted?
Yes it has one a clutch pedal.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
1998 NATIONAL TRAILER (A55745)
1998 NATIONAL...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
