Disc Harrow Can my Ford/NH model 1920 pull a 6' disc harrow effectively?
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #1
rootytoot
Western Oregon
Ford/NH Model 1920, Allis Chalmers Model G
I have a 1989 Ford model 1920, reasonably good shape, about 550 hours on the proof meter. The tractor is diesel, 4x4, 32hp at PTO, 25hp at drawbar, currently does not have fluid in the tires (though I could put fluid in if it was recommended for the task of discing). I'm thinking of buying a 6' disc harrow, of the usual type with four gangs of four discs, attached via three point hitch. Weights are in the 600lb range, so about 40lb per disc. I'm in the Willamette Valley of Oregon, with soil that is pretty heavy clay content. Do you think that the proposed tool is too much for my tractor? When I inquired at Everything Attachments they pointed me toward a lighter weight, non-adjustable version of a disc harrow, which I took to mean the one I proposed probably was too heavy/too much drag.
I think the one I proposed was the ETA-XD-BF-DH-16-18, which is 18" discs and a weight of 686 pounds. The one Jeremy recommended was ETA-XD-AI-DH-16-16-N.
Thanks for your advice.
Kurt
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #2
Suggest a Landpride DH1572 with notched blades, depending on what you are discing. Weighs in at 714# with 18" blades. The 1920 hitch is rated at 1881 lbs.
Also, would recommend loading the rear tires. Will make a big difference.
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #3
You can do it. But all tires need to be filled with weight. We use water and a gallon of anti freeze in the rears. Less than a gallon in fronts with water. We have an older model 1900, about 1980 year. Weight is key. We also have 4 weights on the front bumper. Weight will be your friend in this.
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #4
Supposedly that tractor is about (edit) 3000lbs and you can add another 600 pounds in the tires. I think it will pull it.
Stay off clay until it’s ready. You can’t rush it or you end up making a mess and perhaps stuck too.
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #5
As a point of reference I pull a 54” inch with 18” discs with my 2400H which is 24 HP and weighs around 2500 lbs with loaded tires and loader frame. No problem pulling it on flat ground.
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #6
Is your Ford 2-WD or 4-WD?
You are marginal in tractor weight and marginal in horsepower for the Disc Harrows suggested. Loaded rear tires will make your tractor less marginal, but still marginal.
Are you primarily interested in smoothing plow furrows, with relatively low penetration, which calls for a Disc with 7" or 7-1/2 pan spacing? Narrow pan spacing provides more implement float, making the implement easier to pull.
Are you primarily interested in penetration, which call for a Disc with 9" pan spacing? Less float with 9" spacing = somewhat deeper penetration.
Penetration will not be very great with any Disc with less than 50 pounds total implement weight bearing on each pan.
Have you considered a PTO powered roto-tiller rather than a Disc Harrow? For working < 6 acres a roto-tiller is almost always the better choice for light tractors.
Have you considered an All Purpose Plow / Field Cultivator / Conservation Plow rather than a Disc Harrow?
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #7
Ford 1920​
Ford 1920 Power
Engine (gross):33.3 hp
24.8 kW
Engine (net):32 hp
23.9 kW
PTO (claimed):28.5 hp
21.3 kW
Mechanical
Chassis:4x2 2WD
4x4 MFWD 4WD
Dimensions
Wheelbase:69.9 inches
177 cm
Weight:2849 to 3069 pounds
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #8
Actually, it all depends on how aggressively you set the wings.
It's four wheel drive. Thank you for your responses. Do you think that pull-behind versus three point mount makes any difference, assuming similar weight per disc, number of discs, and angle of gangs? I'm guessing not.
   / Can my Ford/NH model 1920 pull a 6' disc harrow effectively? #10
Typically 3 point you can pull a little more since part if the weight is carried by the tractor.
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
Bunker Rake (A59228)
Sedan (A59231)
Sedan (A59231)
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
1459 (A57192)
1459 (A57192)
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
