can my 28 hp tractor pull a 5-6' double row disc?
   / can my 28 hp tractor pull a 5-6' double row disc? #11
Re: can my 28 hp tractor pull a 5-6\' double row disc?
6' disc should be fine... My 1952 ford 8n can pull a ford 5.5' dual ganged disc.. might have to use breaks, or 4wd to steer though. Soil conditions will also dictate how much bit you can use on the angled rear gang.
Notched discs cut through vegitation better..
Soundguy
   / can my 28 hp tractor pull a 5-6' double row disc? #12
Just have to remember to lock the lever for the brakes at higher speeds on the road because if you hit just one side while moving quickly the tractor may get a little squirrely
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
