can my 28 hp tractor pull a 5-6' double row disc?
   / can my 28 hp tractor pull a 5-6' double row disc? #11
Re: can my 28 hp tractor pull a 5-6\' double row disc?
6' disc should be fine... My 1952 ford 8n can pull a ford 5.5' dual ganged disc.. might have to use breaks, or 4wd to steer though. Soil conditions will also dictate how much bit you can use on the angled rear gang.
Notched discs cut through vegitation better..
Soundguy
   / can my 28 hp tractor pull a 5-6' double row disc? #12
Just have to remember to lock the lever for the brakes at higher speeds on the road because if you hit just one side while moving quickly the tractor may get a little squirrely
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
2022 KUBOTA SVL65-2 SKID STEER (A52707)
2022 KUBOTA...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
