Can I usee copper pipe for exhaust pipe?
   / Can I usee copper pipe for exhaust pipe? #1
Looking4new
Super Star Member
Northern Ontario, Canada
2012 Kioti CK27HST w/cab
The typical exhaust gas temperature is 1,000 F. Copper melt point is about 1900 F. Why cant I use copper pipe for exhaust pipe?
   / Can I usee copper pipe for exhaust pipe? #2
Once it gets real hot (towards manifold) it's going to anneal and get very soft, it's already soft to begin with. The vibration from the running engine will more than likely make your joints fail in no time with the heat. Ever wonder why you don't see things restored with copper exhaust? Because it won't hold up well.
   / Can I usee copper pipe for exhaust pipe? #3
Electrical conduit works well & not to heavy lasted over 20 years on my last tractor.
   / Can I usee copper pipe for exhaust pipe? #4
If the exhaust were short,, copper would work, it would be strong enough.
The big concern I would have is safety.
With copper, the outside temp would be close to the inside temp.
With steel, the conductivity is so bad,, the exterior is MUCH cooler.
How badly you are burned by accidental contact has much to do with the rate of heat flow.
Copper has VERY high heat flow,,, :eek:
   / Can I usee copper pipe for exhaust pipe? #5
Why not? Give it a try. Copper may be more expensive than steel.
   / Can I usee copper pipe for exhaust pipe? #6
Why would you want to? What are your thoughts on a benefit of using it? I don't see any..
   / Can I usee copper pipe for exhaust pipe? #7
Copper work hardens, if temps aren't causing annealing, vibration might lead to fractures if not fully supported...
Nick
I don't have torches/welder or the means to bend steel piping, I can buy short radius copper elbows. That is the reasoning behind it.
   / Can I usee copper pipe for exhaust pipe? #9
Why not buy flexible metal exhaust as sold by most auto parts.
No need for elbows etc and simply use 'U' clamps to attach.
From memory it can be had from 1" thru 2.5" in 1/4 inch increments, might however be 'special order' at some stores.
   / Can I usee copper pipe for exhaust pipe? #10
You can get angled exhaust pipe connectors use band clamps, u clamps or weld up. If you don't have a welder mock everything up mark it take it to a welding shop or muffler shop have them weld it.
Mower King Brush Cutter (A53317)
Mower King Brush...
John Deere 650K (A53314)
John Deere 650K...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
John Deere 7130 (A53314)
John Deere 7130...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
UNUSED FUTURE MINI EXCAVATOR WOOD GRABBER (A57193)
UNUSED FUTURE MINI...
