Grapple Can I use my rear remote to operate a grapple?
   / Can I use my rear remote to operate a grapple? #11
What you have is called "Power Beyond", a continuous flow of hydraulic oil whenever the tractor is running for things that have their own valves like backhoes and logsplitters.
These guys have a "extra" valve on their machine's to control cylinders on attachments. It's called a "remote" or "SCV"
Thanks.
   / Can I use my rear remote to operate a grapple? #12
I have a JD 3320 with Rear Remotes that are actuated by the SCV.....and I have a JD hardlines kit to run fluid to the front of my loader - where I have my couplers AND a grapple. This combination works S L I C K. I have never wanted for more convenience. Why spend more?
OH.....and I have 1/4" couplers and hoses at the front. Just right. :)
   / Can I use my rear remote to operate a grapple? #13
I plug my grapple into the rear remotes and (using the control in my cab) it works fine.
   / Can I use my rear remote to operate a grapple? #15
I had an extra SCV added to my rear (one came standard) and had that hooked up to the third function piping which was the same size as the bucket tilt tubes and hoses. I would have to unplug it if I ever needed two functions at the rear but that takes just a minute. Right now I'm using the third function as the power angle for a eight foot Fisher plow. If anything I have too much flow for those plow pistons and it will snap it around with a bang if I more then crack the control lever next to the seat.
   / Can I use my rear remote to operate a grapple? #17
Get yourself a flow restrictor and that super quick hydraulic movement will get slowed down to a nice manageable adjustment. ;)
   / Can I use my rear remote to operate a grapple? #18
It's on my to do list but not at the top just yet. I know how to crack a valve and do things easy so it isn't a pressing need.
Thanks to all who've replied. I''ve purchased the grapple and required hoses. Works like a charm as long as I remember to put the rear remote back in neutral after opening or closing.
   / Can I use my rear remote to operate a grapple? #20
Congratulations! What type of grapple did you get!
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
1988 FREUHAUF  STEP DECK CRANE TRAILER (A55745)
1988 FREUHAUF...
2005 John Deere 310G 4x4 Extendahoe Loader Backhoe (A55851)
2005 John Deere...
