Posthole Digger Can I use a 24 inch auger on a PTO powered PHD?
   / Can I use a 24 inch auger on a PTO powered PHD? #1
andrewj
Platinum Member
South Carolina
JD 5105
I need to plant some large seedling trees...my 12 inch auger is not big enough...I tried drilling two holes, doesn't work...
so, can my leinbach PHD run a 24 inch auger?
   / Can I use a 24 inch auger on a PTO powered PHD? #2
the guy that sold my mine said you can
   / Can I use a 24 inch auger on a PTO powered PHD? #3
A lot of them don't, but some do. check your model on the company website, they probably will tell you.
   / Can I use a 24 inch auger on a PTO powered PHD? #4
Maybe, could depend on a lot of things.
Tractor you're using.
Soil.
May need to install a different shear bolt to handle the stress if the gear box can handle it.
In soft sand with enough engine power and a good bolt.......do it. In rocky clay with marginal tractor.....don't do it.
   / Can I use a 24 inch auger on a PTO powered PHD? #5
I use a 9 inch auger and punch 3 holes and dig out the rest with a spade and it works just fine
   / Can I use a 24 inch auger on a PTO powered PHD? #7
if you have problems first go slow or drill out 12" pilot hole then open it up tp 24"
   / Can I use a 24 inch auger on a PTO powered PHD? #8
That's a really good way to bind up your 24 inch auger when it takes a sudden bite in the hole. You will shear the pin or choke down your tractor, and the auger will be screwed in tight.
If it happens, use a big pipe wrench and a cheater bar to screw the auger out in reverse.
24 inch augers are a totally different animal.
   / Can I use a 24 inch auger on a PTO powered PHD? #9
If it has a clutch, no problem.
If the dirt is hard and dry, no problem. (although slow going)
If the dirt is moist and chewy, problem.
If your rear tires are filled with water, it helps a little.
   / Can I use a 24 inch auger on a PTO powered PHD? #10
I have dug holes for planting trees with an inexpensive 3pt PHD but it wasn't designed for bits that big. I have no rocks or roots but fairly hard black dirt. Kept tractor at near idle used higher grade bolt for shear pin. I did try drilling a 9" hole first but it is best to just dig with the bigger bit and no pilot hole. The big bit will grab too much when starting with a pilot hole. I used a bobcat 24" bit and made a pipe adapter for fit my PHD which had a smaller diameter. I also added an extra 100 lbs in suitcase weights on the PHD. I used a Kubota 3710 on the PHD. Too big of a tractor and something will probably break. I figured it was best to kill the tractor but this rarely happened. The key is to dig SLOWLY and be ready to raise phd quickly. I did about 15-20 holes, 2' deep.
T3 Motion Patroller Segway (A48082)
T3 Motion...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A48081)
2015 Ram 1500 4x4...
2013 Ford Escape SUV (A48082)
2013 Ford Escape...
2010 Ford Expedition XLT 4WD SUV (A48082)
2010 Ford...
2014 Chrysler 200 Touring Sedan (A48082)
2014 Chrysler 200...
