Posthole Digger Can I use a 24 inch auger on a PTO powered PHD?
   / Can I use a 24 inch auger on a PTO powered PHD? #1
andrewj
Platinum Member
South Carolina
JD 5105
I need to plant some large seedling trees...my 12 inch auger is not big enough...I tried drilling two holes, doesn't work...
so, can my leinbach PHD run a 24 inch auger?
   / Can I use a 24 inch auger on a PTO powered PHD? #2
the guy that sold my mine said you can
   / Can I use a 24 inch auger on a PTO powered PHD? #3
A lot of them don't, but some do. check your model on the company website, they probably will tell you.
   / Can I use a 24 inch auger on a PTO powered PHD? #4
Maybe, could depend on a lot of things.
Tractor you're using.
Soil.
May need to install a different shear bolt to handle the stress if the gear box can handle it.
In soft sand with enough engine power and a good bolt.......do it. In rocky clay with marginal tractor.....don't do it.
   / Can I use a 24 inch auger on a PTO powered PHD? #5
I use a 9 inch auger and punch 3 holes and dig out the rest with a spade and it works just fine
   / Can I use a 24 inch auger on a PTO powered PHD? #7
if you have problems first go slow or drill out 12" pilot hole then open it up tp 24"
   / Can I use a 24 inch auger on a PTO powered PHD? #8
That's a really good way to bind up your 24 inch auger when it takes a sudden bite in the hole. You will shear the pin or choke down your tractor, and the auger will be screwed in tight.
If it happens, use a big pipe wrench and a cheater bar to screw the auger out in reverse.
24 inch augers are a totally different animal.
   / Can I use a 24 inch auger on a PTO powered PHD? #9
If it has a clutch, no problem.
If the dirt is hard and dry, no problem. (although slow going)
If the dirt is moist and chewy, problem.
If your rear tires are filled with water, it helps a little.
   / Can I use a 24 inch auger on a PTO powered PHD? #10
I have dug holes for planting trees with an inexpensive 3pt PHD but it wasn't designed for bits that big. I have no rocks or roots but fairly hard black dirt. Kept tractor at near idle used higher grade bolt for shear pin. I did try drilling a 9" hole first but it is best to just dig with the bigger bit and no pilot hole. The big bit will grab too much when starting with a pilot hole. I used a bobcat 24" bit and made a pipe adapter for fit my PHD which had a smaller diameter. I also added an extra 100 lbs in suitcase weights on the PHD. I used a Kubota 3710 on the PHD. Too big of a tractor and something will probably break. I figured it was best to kill the tractor but this rarely happened. The key is to dig SLOWLY and be ready to raise phd quickly. I did about 15-20 holes, 2' deep.
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2007 Chevrolet Impala Sedan (A48082)
2007 Chevrolet...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2002 International 9200i Truck (A51039)
2002 International...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
