I have dug holes for planting trees with an inexpensive 3pt PHD but it wasn't designed for bits that big. I have no rocks or roots but fairly hard black dirt. Kept tractor at near idle used higher grade bolt for shear pin. I did try drilling a 9" hole first but it is best to just dig with the bigger bit and no pilot hole. The big bit will grab too much when starting with a pilot hole. I used a bobcat 24" bit and made a pipe adapter for fit my PHD which had a smaller diameter. I also added an extra 100 lbs in suitcase weights on the PHD. I used a Kubota 3710 on the PHD. Too big of a tractor and something will probably break. I figured it was best to kill the tractor but this rarely happened. The key is to dig SLOWLY and be ready to raise phd quickly. I did about 15-20 holes, 2' deep.
