fatjay
Veteran Member
I have a strong running Oliver backhoe. It痴 a great matching but the hoe is a bit on the slow side. The hydraulic pump is mounted on the front and swapping should be fairly easy, I would like to find a higher flow pump to speed it up, especially when I move 2 cylinders at the same time. When I move one it痴 not quick but when I move 2 it almost doesn稚 move at all.
