Can I remove mid PTO...
/ Can I remove mid PTO... #1
jdrotert
NW of St. Louis, MO area
B2150DT
It seems that the mid PTO hangs a little too low for my comfort. Has anyone removed theirs and replaced with a plate and a gasket? Looking at my handy parts manual, it seems that the mid PTO just mounts under the transmission with 4 bolts.
I guess next time I change the hydraulic fluid, I'll remove the mid PTO and make a cover for it. Anyone done this?
john
/ Can I remove mid PTO... #2
I have a b2150hsd, I guess the previeous owner removed it because all I have there is a plate and the tractor runs fine.
/ Can I remove mid PTO... #3
What kind of tractor do you have and what seems to be the problem that you think that you'll have with the mid-PTO?
How about a mid-PTO shaft cover?? I have a B2150HSD. On my tractor the mid-PTO works simultaneously with the rear PTO (they operate independently on newer Kubota tractors) and had a problem with grass wrapping around the mid-PTO shaft while using the rear rotary mower. The grass that was tightly would around the spinning mid-PTO finally caught fire and dropped off...not a good thing in a field full of dry grass. Luckily nothing catastrophic happened. But I did learn that there is a cover for the mid-PTO that eliminates that problem. If that is similiar to your problem then I would recommend that cover rather than removing the mid-PTO.
Kelvin
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
1997 International 3800 School Bus (A64194)
1997 International...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
John Deere 5220 53HP Loader Utility Tractor (A64194)
John Deere 5220...
2016 International WorkStar 7500 T/A Dump Truck (A64556)
2016 International...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
