Can I put a dryer vent duct under a concrete slab?
   / Can I put a dryer vent duct under a concrete slab? #31
Every elbow is equal to 10' straight run, possibly more. Shortest length possible, otherwise you are killing the dryer's efficiency.
If it makes any difference, I didn't run the duct under the slab, and instead it runs straight out of the back of the dryer, through a closet (I put a shelf over the ductwork) and out the wall. We used to have the dryer upstairs and it had to go through about 15' of pipe plus one elbow to get out. Now that it's a straight shot, it does dry the clothes much more efficiently.
Good luck and take care.
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55315)
GMC 3500 Extended...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2015 UTILITY VS2RA...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56435)
2019 BOBCAT T630...
