Can I put a Backhoe on my NH TC 33D, and how do I start?
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #11
I believe the tc33 is bigger than my 2003 tc30 , at least same size ?? I have used my TC30 with a sub-frame mounted 757BH on it since purchase . Over 800 hours on tractor without any issues . The issue with the NH tractors cracking / breaking in the middle was in My Belief , Entirely Operator Error . Either in set up installing the BH or in operation .
When installing my BH , I still need to use the top link as a connection point , even with a sub-frame . When connecting the top link , the more down pressure I put on the dipper stick , the tighter I can get the top link , WHICH is exactly the Opposite of what I do . Sitting level , no part of BH on ground , I snug up top link as tight as I can with bare hands , then with just a wrench , I try to get 1/2 to 1 additional turn . That is it .
Operational error is thinking You have a 360 excavator when instead You have a 30 hp tractor . Using stabilizers to raise rear wheels off the ground , Using front loader to raise front end of the ground . DUH , Yes it is going to break in the middle . There were people here who experienced this problem , I asked specific questions , which most were not replied to or answers did not add up .
My brother has a similar sized JD tractor which We added a aftermarket 3 point BH to . It has its own Hyd. tank and pump , thus just connects to the pto of tractor . After some redneck engineering , We came up with a solution to more easily install that BH on his tractor . The issue centered around the top link that came with the BH . Anyway , That BH is attached the same way as I attach mine , as far as tension on the top link and operation of the BH.
My Opinion , Yes , You can attach a BH to your tractor , either sub-frame or 3 point , BUT with the Understanding that it is NOT a 360 excavator or a 580 BH .
Fred H.
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #12
Hi gang,
I'd like to put a backhoe on my NH TC 33D instead of buying a whole new tractor. I'm not very savvy about hydraulics and how to retro-fit, so I'm open for any suggestions on how to begin and what type/brand/size of backhoe would be appropriate.
Thanks for your help!
SOB139
The BEST way to "begin" would be to list your current TC 33D on Craigslist!
Then: Find whatever size tractor you want, with a sub-frame, and quick disconnect hoe.
30+ years ago I had the your same dilemma.
Ford dealer said; "let me find something for you".
It took 22 months, but he found me a lightly used Ford 3400 TLB (gas-cemetery machine), with quick attach hoe.
I still have it ....and I love it!
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #13
Many backhoes come with valves, and you can do with as little as one supply hose (power beyond) and one drain (that can continue the power beyond to the 3-point lift.) I could adapt the backhoe that came with my Mahindra to many different tractors with a little fab work.
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #14
Making them fit isn't the problem. What's your hydraulic pump's GPM rating?
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #15
I've a Kioti Ck20 that I mated a NH backhoe to. The backhoe came with the stock NH frame that I modified to work with my tractor. I made quick attach mounts that stay on the tractor. I can mount/dismount the hoe in under 5 minutes max. The hoe cost me $3000, plus maybe $100 in steel to make my mounts. Works really good, doesn't stress my tractor at all, runs off the tractor hydraulics - typically engine at 1800 to 2000rpms, I've done a ton of work with it.
While I don't have a 3pt hoe I did look at them but I'm glad I went with the frame mount. Frankly even if I had a 3pt I'd likely modify it to have a frame. It's simple to do and much stronger.
Biggest challenge will be looking and waiting for a good deal to pop up in your area. It took a while before I found mine. Had to drive 150miles but that was worth it. If it's a long drive see if they will do something like a skype video chat to show you the unit.
No my tractor isn't the fastest hoe in the world but for the jobs I need it to do it works great. If you're expecting it to dig with the efficiency of a mini-ex then you'd better just get a mini-ex as no tractor mounted hoe will work like those.
E.
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
Hesston 565T Round Baler (A50514)
Hesston 565T Round...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
TEST BID LOT (A50775)
