Can I put a Backhoe on my NH TC 33D, and how do I start?
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #11
I believe the tc33 is bigger than my 2003 tc30 , at least same size ?? I have used my TC30 with a sub-frame mounted 757BH on it since purchase . Over 800 hours on tractor without any issues . The issue with the NH tractors cracking / breaking in the middle was in My Belief , Entirely Operator Error . Either in set up installing the BH or in operation .
When installing my BH , I still need to use the top link as a connection point , even with a sub-frame . When connecting the top link , the more down pressure I put on the dipper stick , the tighter I can get the top link , WHICH is exactly the Opposite of what I do . Sitting level , no part of BH on ground , I snug up top link as tight as I can with bare hands , then with just a wrench , I try to get 1/2 to 1 additional turn . That is it .
Operational error is thinking You have a 360 excavator when instead You have a 30 hp tractor . Using stabilizers to raise rear wheels off the ground , Using front loader to raise front end of the ground . DUH , Yes it is going to break in the middle . There were people here who experienced this problem , I asked specific questions , which most were not replied to or answers did not add up .
My brother has a similar sized JD tractor which We added a aftermarket 3 point BH to . It has its own Hyd. tank and pump , thus just connects to the pto of tractor . After some redneck engineering , We came up with a solution to more easily install that BH on his tractor . The issue centered around the top link that came with the BH . Anyway , That BH is attached the same way as I attach mine , as far as tension on the top link and operation of the BH.
My Opinion , Yes , You can attach a BH to your tractor , either sub-frame or 3 point , BUT with the Understanding that it is NOT a 360 excavator or a 580 BH .
Fred H.
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #12
Hi gang,
I'd like to put a backhoe on my NH TC 33D instead of buying a whole new tractor. I'm not very savvy about hydraulics and how to retro-fit, so I'm open for any suggestions on how to begin and what type/brand/size of backhoe would be appropriate.
Thanks for your help!
SOB139
The BEST way to "begin" would be to list your current TC 33D on Craigslist!
Then: Find whatever size tractor you want, with a sub-frame, and quick disconnect hoe.
30+ years ago I had the your same dilemma.
Ford dealer said; "let me find something for you".
It took 22 months, but he found me a lightly used Ford 3400 TLB (gas-cemetery machine), with quick attach hoe.
I still have it ....and I love it!
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #13
Many backhoes come with valves, and you can do with as little as one supply hose (power beyond) and one drain (that can continue the power beyond to the 3-point lift.) I could adapt the backhoe that came with my Mahindra to many different tractors with a little fab work.
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #14
Making them fit isn't the problem. What's your hydraulic pump's GPM rating?
   / Can I put a Backhoe on my NH TC 33D, and how do I start? #15
I've a Kioti Ck20 that I mated a NH backhoe to. The backhoe came with the stock NH frame that I modified to work with my tractor. I made quick attach mounts that stay on the tractor. I can mount/dismount the hoe in under 5 minutes max. The hoe cost me $3000, plus maybe $100 in steel to make my mounts. Works really good, doesn't stress my tractor at all, runs off the tractor hydraulics - typically engine at 1800 to 2000rpms, I've done a ton of work with it.
While I don't have a 3pt hoe I did look at them but I'm glad I went with the frame mount. Frankly even if I had a 3pt I'd likely modify it to have a frame. It's simple to do and much stronger.
Biggest challenge will be looking and waiting for a good deal to pop up in your area. It took a while before I found mine. Had to drive 150miles but that was worth it. If it's a long drive see if they will do something like a skype video chat to show you the unit.
No my tractor isn't the fastest hoe in the world but for the jobs I need it to do it works great. If you're expecting it to dig with the efficiency of a mini-ex then you'd better just get a mini-ex as no tractor mounted hoe will work like those.
E.
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
Chisel Plow with Cultivator Sweeps (A52128)
Chisel Plow with...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
