Can I mix it with water?
   / Can I mix it with water? #1
rooster628
South Texas
Fighting s. TX brush (mainly mesquite) and want to know if I can mix the Remedy with water instead of diesel like dad always did? With Remedy at $100/jug, what is the preferred amount of Remedy to use when mixing up a batch?
   / Can I mix it with water? #3
Rooster i use remedy 2 oz per gallon of water, more than normal for spraying soda apples in pastures. Check with your neighbors, i am sure the mixture would be heavier for your application. It may be that some deisel mixed in would have it stick to the plants better.
   / Can I mix it with water? #5
I never used Remedy on my Mesquite but my neighbor does and it's diesel, the diesel sticks to the tree better.
The best method is a bulldozer from what i've seen;)
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
23169 (A50324)
23169 (A50324)
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
CATERPILLAR 120 M2 MOTORGRADER (A52705)
CATERPILLAR 120 M2...
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
2018 KENWORTH T680 SLEEPER (A54607)
2018 KENWORTH T680...
